97 lt1 LOUD knock
Old Jun 10, 2008 | 09:16 PM
outlawtorn's Avatar
97 lt1 LOUD knock
I have a 97 z28 with 108k on it... My transmission went out about a month ago and its been sitting at my shop untouched since. Well today i was gonna pull it down to the tranny shop to have the tranny rebuilt so i fired it to have it pulled and when i did so it started knocking horribly... i shut it off because i had no idea what it was. I started it back up a few minutes later and let it run.. there was a bad knock then after oil pressure came up it quited down a little but is still loud its more then just a slight tick. I have no idea what would cause it since it ran fine when i parked it. Any ideas?
Old Jun 10, 2008 | 10:47 PM
SS RRR's Avatar
Depends on what kind of "knock" it is. Could be a bad lifter. Could be a rod knock...
What does it sound like? It is high pitched almost a metallic "tingy" like or is it low and deep?
Old Jun 10, 2008 | 11:33 PM
outlawtorn's Avatar
i dont know how it would be a rod knock since it was fine right before i parked it.... it honestly sounds like someone is hitting the valve cover with a hammer i know what piston slap sounds like and i know what a bent rod sounds like this is a bad slapping almost noise
Old Jun 11, 2008 | 12:49 AM
SS RRR's Avatar
Have you taken the valve covers off yet?
Old Jun 11, 2008 | 02:46 AM
blk95's Avatar
lifters bled down?, I would let it run for a little while after you get it back together and see if it clears up if it is a tick like sound, if it is a deep sound it may be more than a lifter.
Old Jun 11, 2008 | 09:09 AM
outlawtorn's Avatar
well it sounded like it was for sure coming from the passenger side so i tore the valve cover off last night and at first glance everything seems to be alright... im gonna take my rockers off tonight and see if i broke a rod or something.... my brother thinks one of my valves is stuck shut after sitting for so long and after i started it i broke a valve spring or something
Old Jun 11, 2008 | 03:55 PM
93transam1234's Avatar
Maybe someone started your car and reved the hell out of it?
ayways best of luck, i hope it is something minor.
Old Jun 11, 2008 | 05:46 PM
Pontiac_97's Avatar
if it sat for a month your lifters could of bled down. like the other person said, run it for a minute or two and see if the lifters pump back up once they get some good oil back in there. i would also see if any of your rockers are loose
Old Jun 12, 2008 | 12:00 PM
outlawtorn's Avatar
i let it run for a minute but it still knocked louder then **** so i just shut it off... i tried to do a compression check last night but i cant even get to the damn spark plugs this car is retarted to work on haha
Old Jun 12, 2008 | 12:28 PM
Is the car in an Auto shop? Doesnt anyone there know anything about cars?
Old Jun 12, 2008 | 05:54 PM
transAMdriv3r's Avatar
it was probably because the oil bleed down from sitting for a while, just like when you change your oil it ticks loud until it builds oil pressure.
bfmv13trivium
Jan 14, 2015 09:57 AM
JSK333
Sep 9, 2002 10:33 PM
96z
Sep 5, 2002 07:53 PM
99TransAmWS6
Aug 9, 2002 12:16 PM
