97 LT1 in a 93
Old Feb 8, 2006 | 03:18 PM
Jazsun's Avatar
97 LT1 in a 93
I am looking at buying a 93 formula w/ 120k, the guy says it has a new motor in it w/ 7k on it from an 97. He says he has recipts that show this. Is this even possible w/ out a lot of fabrication. Also where the heck do you buy a new motor from a 97 ? I noticed in the engine pics of the car it still has speedensity. Is it possible to put a 97 motor in but use the 93 pcm and harness and still use speed density?
Old Feb 8, 2006 | 03:25 PM
12sec94z28's Avatar
Re: 97 LT1 in a 93
i dont see why not. All of the Lt1's are very similiar in wiring harness. I put a 96 in a 94. Some of the connections are different, but all of the ones that you need for it to run are the same. I dont see there being an issue. Its sounds like it is a 97 motor and he just used the 93 intake setup and is running that 93 pcm.
Old Feb 8, 2006 | 03:28 PM
stingercamaro's Avatar
Re: 97 LT1 in a 93
I'm just finishing up a motor swap of a 96 Z into a 93 Formula so I'd definitely say that is possible.
Old Feb 8, 2006 | 03:30 PM
Z95m6's Avatar
Re: 97 LT1 in a 93
yes its very easy and very possible to put a 97 motor into a 93 car. Check and see if it has a vented opti for one, or pull the valvecover and look at the cylinder head part number.
Old Feb 8, 2006 | 04:41 PM
2000GTP's Avatar
Re: 97 LT1 in a 93
The motor from the 97 is still an LT1 so there is not much fabrication needed to do the swap. As mentioned above, it sounds like the longblock is a 97 but with a swapped intake/computer from a 93.
Old Feb 8, 2006 | 05:01 PM
Jazsun's Avatar
Re: 97 LT1 in a 93
Thats interesting. Do you really need to swamp in the intake manifolds, couldnt you just reuse the intake elbow etc..Now that I think of it, the intake in the pics does look fairly old, not like brand new so I am guessing that is what he did.
Old Feb 8, 2006 | 05:10 PM
blkchevyz's Avatar
Re: 97 LT1 in a 93
depending on how much of the 93 he put on the 97, you should beable to look at the timing cover and see a conection for a crank sensor.
but he could of put a 95 cover on it, or put the 93 cover and non vented opti... bla bla bla
Old Feb 8, 2006 | 05:17 PM
Z95m6's Avatar
Re: 97 LT1 in a 93
Well the intake manifolds are different between a 93 and a 94+ car. The intake elbow is also different and can't easily add a MAF.
Old Feb 8, 2006 | 07:51 PM
Jazsun's Avatar
Re: 97 LT1 in a 93
He is asking 5k for it. Im gona offer like 4,100. Do you think thats reasnable assumng the bottom end has 7k on it, and its a 6spd 93'(better ratios then the 93+ t56's)
Old Feb 9, 2006 | 09:32 AM
blkchevyz's Avatar
Re: 97 LT1 in a 93
yikes, 4100
you could build a nice 355, with heads for that much, and still have money left over.
Old Feb 9, 2006 | 11:54 AM
JimboManJones's Avatar
Re: 97 LT1 in a 93
I say more then half the people on this site need to read more carefully. He is not buying a motor, he is buying a whole car. Go read his post again. He would have to be totally retarted to buy a stock used motor for 4100.
I guess 4100 wouldn't be so bad, depending on the options/condition of the car. Give it a shot, good luck with the car if you get it.
Old Feb 9, 2006 | 11:59 AM
blkchevyz's Avatar
Re: 97 LT1 in a 93
opps
Old Feb 9, 2006 | 02:05 PM
Z95m6's Avatar
Re: 97 LT1 in a 93
I don't think he could be using the 93 cover and opti unless he put the 93 cam in the motor. As the opti is driven differently.
Old Feb 9, 2006 | 02:15 PM
blkchevyz's Avatar
Re: 97 LT1 in a 93
yeah thats what the bla bla bla stuff was
Dave89IROC's Avatar
Re: 97 LT1 in a 93
could have cut the dowel and used a 93/94 timing set
but it probably has the vented opti and crank senmsor
