96 Ws6 Stumbles At Idle While In Gear
Old May 25, 2005 | 01:12 AM
Buk's Avatar
Buk
So heres the deal: I have a 1996 Trans Am Ws6 which I just bought a week ago, which is one of the cars I have always wanted! Its been awesome the past week, and still has a boat-load of power and seems to have been well taken care of its 74000 miles. However, today while I was cruising around it began to develop a slight stumble every once in a while at idle, but ONLY when in gear. (Not P or N, its fine in those) Its not enough to kill the engine but is very noticeable when it happens. (rpms fluctuate 400-900) Once you give it some gas it goes right away so I'm assuming its something like my throttle body needing cleaning?? Hopefully some of the Fbody guys can give me their thoughts on this so I can get her running smooth again.
Old May 25, 2005 | 01:56 AM
93turbo5oh's Avatar
Re: 96 Ws6 Stumbles At Idle While In Gear
mine did that right before the original opti took a dump at 72K.
Old May 25, 2005 | 02:12 AM
2000LS1Z28's Avatar
Your car is an A4, correct?
Well let me tell ya...When I bought my '95 Z28 w/ about 109,000 on the clock last fall it was acting exactly as you described with yours. A warm idle while in gear (sitting at a light for example) would stumble sometimes. Idle would be normal (550 factory setting), then out of nowhere it would just drop to about 400ish for a second or so and jump back up to the correct idle speed. Never died, but felt like it wanted to, LOL. Once you gave it some gas and got it moving it was all good.
Turned out to be the IAC (Idle Air Control) valve. Had a really low count right at 0. There was a small vacuum leak. Got that fixed and had the throttle body cleaned as well. Idle has now been perfectly solid since then (knock on wood).
Check that out first though (don't just assume it's the opti like so many do). Now if you're having consistent misses in the rpm band while cruising or at full throttle, then I'd look hard at the opti, plugs & wires, coil, ICM, etc.
Good luck,
Mike
Old May 25, 2005 | 06:53 AM
1quickTA's Avatar
I had a problem somewhat similar to that. It turned out to be a broken vacuum hose, in my case the one that comes out of the passenger side of the throttle body. Take a look around and see what you can find. You might be able to hear it if it is a vacuum line - it would just sound like a lot of air being blown out of / sucked into a tube. Good luck.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ChrisFrez
Mar 1, 2015 01:33 PM
Dave19yz28
Jan 26, 2003 01:45 PM
