96 Vette LT-1 in 96 Z-28 install issues?
Old Oct 9, 2006 | 07:31 PM
doo_man's Avatar
I am in the process of installing a Vette LT-1 in my Z-28, there are some small issues holding me up. I realize they are identical engines other than accessories mounted differently and 4 bolt mains. I read that the oil pans are different, something about interfering with the crossmember on the f-bodys. My Z-28 pan won't clear the oil pump pick-up, do I have to modify or can I order an aftermarket pan? Anybody with some experience with this, or will the stock Vette pan clear the crossmember?
Old Oct 10, 2006 | 03:35 AM
unforgiven's Avatar
Re: 96 Vette LT-1 in 96 Z-28 install issues?
The vette pan will not clear. Just get a new oil pump pick up. Be sure to have it welded on.
Old Oct 10, 2006 | 09:28 AM
Z28SORR's Avatar
Use both the pan and pick-up from the Camaro! Or get a nice after market pan w/pick-up.
Old Oct 10, 2006 | 10:09 AM
KGRESOCK's Avatar
Correct I recently swapped a 94 c4 engine into a 95 fbod.
Even with a tubular cross member I needed the camaro pan/pickup.
Good luck!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
cmdeshon
Jan 4, 2015 11:15 AM
