96 SS stock CAI vs K&N CAI...
My 96 SS still has it's stock cold air from SLP... however I really doubt how effective it is since it does a 180 into the TB... and I think most air runs over the hood scoop and is not "rammed" in there anyways, so I'm thinking of switching to the K&N CAI... Would it be worth the money to get this? Or does the stock one work better than I think? I've never seen any pictures of anyone who still has it.. they have all seemed to switch to something or other that runs to the fender. Plus I think it cleans up the engine bay anyways.. so does the K&N cai work much better than the stock? Thanks
Trevor
Trevor
Really? The LS1 set up is crap? I always though it was much better....
Well thanks.. great, that saves me some money that I can put into something else now
Oh btw... since the intake does like a 180 into the TB... would buying an air foil in an attempt to straighten that out as much as possible be worth it? I don't know if air foils are BS or not... thanks
Trevor
Trevor
Airfoils are a waste of money. Period.
The reason the LS1 setup sucks is because the air gets split into two different tracks in the hood and that both make 360* turns and then through the airbox. I guess the only difference would be that the LT1 cars have the airbox before the bend and the LS1 has the airbox after the bends.
Oh.. well then everything just seems to be dropping of my "to buy" list.. now the only I'm buying are my FLP long tube header set up... so now that I have all this extra money kicking around... any suggestions on what would be worth my time and money to go with my headers?
SS ram air
I swithched mine to a Moroso CAI because I had my intake powder coated and wanted to see more of the motor. It was also starting to crack and I don't think it ever sealed right to the hood. I had a K&N filter in the SS airbox in place of the factory filter. I always felt like the ram air worked judging by the amount of dirt and crud in the filter. As far as any horepower of et gains I don't think I gained or lost anything. If I didn't get the cai for next to nothing I would still be running the stock box. I also wanted to keep the stock ramair box in as good of shape as possible just in case these cars are worth something in the future.
It was proven years ago that the LT1 SS air box setup is costing .2 sec.
Same day at track, switched to a CAI and picked up .2. Same 60' times. Car was hot lapped to see if it was because of sitting. Still was .2 second faster without the stock setup.
Quite a few people back then had the same results.
