96 motor in 95 Z
Old Nov 3, 2011 | 04:36 PM
JackBlack95's Avatar
96 motor in 95 Z
Looking to put a LT1 out of a 96 into my 95 Z28. Is this a bolt in deal? Doesn't the 95 use OBD1 and the 96 use OBDII?
Old Nov 3, 2011 | 04:42 PM
Re: 96 motor in 95 Z
Yes but if you use your current computer and KS, it won't matter.
Old Nov 4, 2011 | 12:26 AM
OBE1 95Z28's Avatar
The 96 engine has a different timing chain cover that houses the crank position sensor. This sensor isn't used with the 95 computer. Be sure to use a crank hub from a 96/97 engine as it's shorter than the 93 - 95.
Old Nov 4, 2011 | 07:29 AM
96capricemgr's Avatar
Just to expand on this. If you remove the crank position sensor reluctor that goes over the lower timing gear then you would use the 95 hub. The 96-7 hub is shorter just to make room for the reluctor.
alex5366
Mar 27, 2015 03:30 PM
transam_388
Mar 15, 2015 11:53 AM
NewsBot
Dec 28, 2014 06:20 PM
