96+ coil info needed for swap
Old Mar 14, 2014 | 09:35 AM
maybe2fast's Avatar
I want to do a LTCC, but for now I think I am going to swap out my old coil for the 96+ coil. I searched and could not find the swap wiring info. HELP!
I did find this info on the coils (experts can help say if it will help the engine, mods in sig)
Performance Specifications Delphi (GM) coils
.................................. .Standard..................Fast Charge
....................................Sing le Coil............... Time Single Coil
Energy (800 V zener)............62 mJ.................... 70 mJ
Peak secondary current ........45 mA................... 74 mA
Secondary voltage available...32 kV.................... 32 kV
Spark duration (800 V zener)...3.1 ms .................2.6 ms
Secondary resistance.............8.3 k ohms........... 5.8 k ohms
Primary resistance.................0.40 ohm............. 0.20 ohm
Primary charge time...............2.0 ms................ 2.0 ms
The Standard Single Coil is the '92 - '95 LT1 coil, the Fast Charge Time Single Coil is the '96 LT1/LT4 coil.
Old Mar 14, 2014 | 10:05 AM
Re: 96+ coil info needed for swap
Comparing these two schematics will show you just what you need to do:
http://shbox.com/1/95_ign_system_schematic.jpg
http://shbox.com/1/1996_ec_03_ign_system.jpg
You will need the single connector pigtail for a newer coil and have to splice in the power to get it to terminal A of the ICM.
Might help a smidge, but I doubt it will be anything you notice.
Old Mar 26, 2014 | 10:25 AM
maybe2fast's Avatar
thanks Shbox!
I am thinking I can clean up the area too with the coil (moving it)
Old Mar 26, 2014 | 10:59 AM
Moving it to where? You want the coil to opti high tension lead as short as possible. I'm sure that was a consideration for the stock location.
Old Mar 26, 2014 | 01:04 PM
maybe2fast's Avatar
I understand now, was thinking it would clean up the area, but I understand the shorter wire...wasn't thinking
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
blac94Z
Feb 10, 2015 11:02 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
