96 coil conversion
Old Feb 13, 2005 | 12:35 PM
ken9c1SS's Avatar
96 coil conversion
Have any of you guys seen or converted to a 96 and up coil.
Old Feb 13, 2005 | 02:51 PM
RE AND CHERYL's Avatar
Re: 96 coil conversion
Whats different about the post 96 coil?
Old Feb 13, 2005 | 05:05 PM
97Z-M6's Avatar
theres not.
but it gave me 25 rwhp when i put one on...
Old Feb 13, 2005 | 05:34 PM
Hawk's Avatar
96 and up coils are supposed to be better.
But upgrading a pre-96 car to a 96 coil is pretty pointless, just buy an aftermarket coil they are better then the 96+ coil anyway.
I have a 96 and I have a accell supercoil in mine.
Brian
Old Feb 13, 2005 | 06:03 PM
Tom Piper's Avatar
I'm not sure about the F-Body, but the Corvette '96 coil and ignition module should be used together as a set. This is definitely an upgraded ignition system for the Corvette.
They were designed with the extended rpm of the LT4 engine in mind. In '96, the Corvette LT1 and LT4 used the same upgraded ignition coil and module.
I converted my '92 Corvette to the '96 ignition coil and module.
The only difference in connectors is the one for the coil -- plus the coil high-voltage wire connection is different.
Tom Piper
Old Feb 13, 2005 | 09:13 PM
OBE1 95Z28's Avatar
I've been running a Crane PS-91 coil with a Crane ignition system in my 10# supercharged setup for 30K miles with no ignition issues. It's even up to the task of a 75 shot of nitrous now and then . I'm running Autolite 103 plugs gapped at .038" and Accel 9000 wires.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
tdigger9899
Sep 7, 2015 10:56 AM
