96 camaro z28 no start. HELP
Old Feb 7, 2011 | 09:58 PM
1996camaroZ's Avatar
Need help. I've posted on a different board but I need all the brains in the world for help.
96 camaro z28. 87K. Auto.
Removed wheel locks with hammer and chisel as the key was lost. Took wheel locks off. Replaced tires and wheels. Car wont start. It did run great.
Car has spark. Car has fuel.
items new in the car are
fuel pump...
Opti with only about 4 miles and 4 months on it. Fuel filter.
I bypassed the Vats key under the steering column. Nothing.
What the car does is...
It will crank and nothing. It will crank and cough once. It crank and cough twice. It will then crank and do nothing. Then back to a cough.
Nothing happend to the car between running good ....then romoving wheel locks...now no starting.
I was going to replace the Crank position sensor but that wont matter as the car is obd II.
I would point to coil or the ICM but there is spark.
Thanks in advance for any and all replies.
P.S.
I've worked on a million cars but the stress level of this one is a record setter.
Last edited by 1996camaroZ; Feb 7, 2011 at 10:00 PM. Reason: forgot to add something
Old Feb 7, 2011 | 10:29 PM
my1994z28's Avatar
Re: 96 camaro z28 no start. HELP
Oh Man,you need to put the wheel locks back on for the car to run!!!! LOL,just kidding...If you have access to a fuel pressure gauge,try putting it on and cranking it over and verify how much pressure you really have..How did you check for spark?Also check the injector fuse.You could always try spraying some starting fluid into the tb and try starting it.
Old Feb 7, 2011 | 10:48 PM
Injector fuse has been checked. Can a ICM or coil still produce spark but be bad????
Old Feb 8, 2011 | 06:48 AM
moparman's Avatar
Have you scanned for any trouble codes?
Old Feb 8, 2011 | 12:24 PM
The code it threw is not related to the non start issue. It was an O2 sensor code that has now been replaced. Code just not cleared.
Still no start.
Old Feb 8, 2011 | 01:43 PM
19z28camaro02's Avatar
MAF fall off somehow??? Check wiring in the back of the fuse box, KOEO Check engine light illuminated(Had this problem myself a few years ago, caused same symptoms)?
Old Feb 8, 2011 | 08:37 PM
Keyon engine off check illuminated light.....
what exactly are you saying. Check the wiring behind the fuse/relay block under hood. And what wiring am I looking for? Which one.
CamaroHeed
Mar 18, 2020 09:50 PM
NewsBot
Dec 28, 2014 06:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
