96-97 emission header install & what style or brand?
Old Nov 21, 2005 | 11:28 PM
psmopar's Avatar
Question 96-97 emission header install & what style or brand?
I am gathering parts for a head/cam swap on a 96 M6 car. The car has 1" Eibach lowering springs and not rubbing or leaving parts in a parking lot is a must. I need to pass emissions insp with some sort of dual cat installed. I have a Spohn non-long tube torque arm installed. I already have a set of coated SLP shorties in a box. It seems that reading several post's the following items are repeated:
#1 - If there's a question of motor mounts change and go with new poly mounts to avoid headers rubbing. Still might rub steering shaft.
#2 - RK's & AS&M have both good and mixed reviews on install plug access and leaking/non-leaking #1 primary slip fit tube.
#3 - Go with 3/4 primaries for a head/cam car vs 5/8 primaries Mac's
#4 - 96-97 shorties are junk unless an aftermarket hi-flow y/cat pipe is installed with SLP shorties
#5 - Long tubes are best but are going to rub and much more difficult to get the dual cats in place.
So Now here's the questions:
1) Are there any long tubes that will not rub and might work with the Spohn non-LT (w/ drive shaft saftey)? Ie: Pacesetter, TPIS, Kooks?
2) If going with mids Are TPIS or another brand a big step over AS&M or RK's?
3) If going with mids what brand cats are recommended to have a custom y pipe fabricated verses buying high dollar Random and be just as good?
4) On a 96-97 w/ mids, are there any recommendations to avoid rubbing other than poly mounts?
5) How much will I lose if the SLP shorties w/ random or similar hi-flow Y is installed verses mids?
6) what items will I need or run into if using 94-95 mid type headers as far a hooking up the AIR tubes?
7) Does anyone have a header-dual cat set up for sale? RK's for sale now $450 and I'd have to fab included y with new cats, I understand Jet-hot has mac's for $650, AS&M bolt in setup w/ everything for $1400+
I reall don't want the headers rubbing due to there are some Huge speed bumps where I drive the car. I need to pass emissions w/o hassle. I want to help the planned head cam swap with out spending a fortune on headers only. I'm Looking for 96-97 car owners with similar setups and exprience on the setup and install. Thanks!
Old Nov 22, 2005 | 03:41 AM
Z95m6's Avatar
Re: 96-97 emission header install & what style or brand?
If you are considering LT's but they won't work with your TA, then just get a set of single cat headers. You can have a custom dual cat y pipe made. Its just the single cat headers have better plug access and make more hp than the 96-97 style headers.
Old Nov 22, 2005 | 05:58 AM
shartflhs's Avatar
I just put in the SLP shorties and a magnaflow on my 96 M6 car a little over a week ago. I am very pleased with the setup, definite difference in performance. I have to deal with emissions also so that was a major concern. I also have a short torque arm that i put in at the same time along with new lower control arms. It was a pain to get them in but I didnt have to do anything with motor mounts and there is no problem with the steering shaft. I did have to take the drivers side motor mount bolt out to give me that little extra room but no big deal. I wouldnt bother with long tubes unless you are really trying to squeak every bit of power out you can. I am sure the head/cam package will work well with the slp's. That is where i am headed. I have another set of heads on the bench ready to be ported. Only concern i have is there is a primary that runs close to one of the heater hoses. Just got some insulation and wrapped it around the hose. Problem solved.
Steve
Old Nov 22, 2005 | 09:23 AM
BUBBA's Avatar
So what's the problem: you have coated SLPs in the box. Put'em on.JMHO
Old Nov 22, 2005 | 10:03 AM
psmopar's Avatar
That's what I thought but it seems several opinions are that the SLP 96-97 shorties are too short for good flow/torque?
I'm not sure because I haven't had experience w/ SLP shorties compaired to mid-type headers. It would be nice to hear from a few that have tried both on a dual cat car.
I am trying to do it the best possible way without spending major bucks and not wanting to have to re-do the header setup later. I may just do that and go with better cats to help access and exhaust flow. I wonder what would be better, modifying my current y-pipe or just shelling out for a random
dual-y if the shortie SLP's is the route chosen?
Old Nov 22, 2005 | 10:07 AM
psmopar's Avatar
I did call Spohn today and one salesperson recommended AS&M's and another saleperson said that kook's LT's will fit non-LT type torque arm. (10 different answers' from 10 different sales people?) It'd be nice to hear from anyone on this board who has phycially used/installed kook's LT's on a 96-97 car & even better w/ a non-LT Spohn torque arm.
If kook's LT's will fit current torque arm and fit tight to under the car that may be the best way to go?
Old Nov 22, 2005 | 10:24 AM
psmopar's Avatar
Steve
Thanks for the input. Sounds like it went well with the shorties. Common sense says just install the shorties and go with it. I am just looking into other people who have tried mid's or some LT's (other than hooker's - I know they'll drag on 1" lower) on a 96-97. I have $400 in the shorties including new coating so I could sell them fairly easily now if another header setup is alot better. I am going to do some more checking...on kooks and TPIS.
Old Nov 22, 2005 | 10:32 AM
psmopar's Avatar
I had a thought....... It would be great if there were some
DYNO COMPARISONS on one type header to another. Preferably on the same car/setup before after?
That would be great to see the REAL HP gains on SHORTIES vs MID's vs LONGTUBES. I fairly sure LT tubes would win....but by how much and same for mid's vs shorties. Does anyone have a dyno #'s before/after header swaps? Thanks..
Old Nov 22, 2005 | 10:41 AM
BUBBA's Avatar
Well, I like many others, had to make a decision about what headers to get.
I have 97SS with the dual cats. I didn't want to have to take a chance with the federales with regard to the regs prohibiting the removal or relocation of factory cats, and I preferred a 1 3/4 primary in Stainless, so I went with the SLPs. Toyed with the idea of going with Clear Image mids. They are 1 5/8s, but really look like they would do a great job. Main problem is that they require the random cat Y pipe and the whole thing costs around $1200.00.
So I bought the SLPs (uncoated) and had finishline coatings put a nice finish on them. I did reroute the one heater hose behind the other hose to keep it away from the primary, but other than that I believe I made the right choice given the alternatives.JMHO
Ringmaster72
Dec 12, 2017 10:12 PM
chevy95z28
Jun 22, 2015 09:28 PM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
