95 z28 lt1
Old Mar 1, 2010 | 05:28 PM
ShowOff67's Avatar
95 z28 lt1
can anyone tell me where i can find the fuel pump relay? having starting problems direct click when trying to crank from the starter checked connectors and they where clean, i think its just time for a new starter?
Old Mar 1, 2010 | 06:11 PM
Guest47904's Avatar
Guest
Fuel pump relay is under the drivers dead pedal. What's that got to do with the starter?
Old Mar 1, 2010 | 06:14 PM
ShowOff67's Avatar
well people have been telling me to check the relay for the fuel pump, i knew it wasnt it because i hear it turn on when i go to crank
Old Mar 1, 2010 | 06:32 PM
bombebomb's Avatar
I would check terminals first, I know you said you checked connectors but was not entirely sure if that is what you ment.
Check for dead battery.
Old Mar 2, 2010 | 04:43 AM
Guest47904's Avatar
Guest
I think you're confusing the fuel pump relay for the Theft Deterrent relay.
Old Mar 3, 2010 | 01:33 AM
omgwtfdied's Avatar
fuel pump relay would not be your problem. terminals.
Old Mar 3, 2010 | 07:21 AM
MTBSully's Avatar
if you can hear the fuel pump prime when you turn the key to the ON position, it isnt a problem with the relay. Check to make sure your battery terminals and grounds are clean and secure.
Old Mar 3, 2010 | 02:56 PM
ShowOff67's Avatar
all terminals are clean and secure but starter still making click noise
Old Mar 3, 2010 | 03:10 PM
Guest47904's Avatar
Guest
Clicking noise is an indication you don't have enough current. There are several reasons for that. The most common is a bad connection, the next most common is a weak or bad battery. Easiest way to check both is jump directly from the battery to the starter. If it doesn't crank then, check the battery voltage while it's being jumped directly to the starter. If it goes below 11 volts, either the battery is low or defective or the starter is shot and pulling too much current.
One thing you have to remember about connections is there are more than just those on the battery itself. The negative battery cable also goes to the body and on the drivers side, a ground strap takes the ground from the body to the engine. Any of these connections can be a problem.
Old Mar 3, 2010 | 03:20 PM
ShowOff67's Avatar
ok this is what happened my brother hooked his jeep up to jump it but when i jumped it still just clicked, could the starters wires be dirty?
Old Mar 3, 2010 | 03:54 PM
edz97's Avatar
Battery is deceased
Old Mar 3, 2010 | 09:14 PM
97venom's Avatar
If all connections are good, take the battery and have it load tested, auto zone or advance auto will do it, if it's good, probably a bad starter
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmdeshon
Jan 4, 2015 11:15 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
