'95 z not starting
Old Sep 9, 2006 | 10:22 AM
redlt1z28's Avatar
'95 z not starting
new batt.,cables are tight,checked fuses.won't even turn over.abs relay clicks when you turn the key to crank it.any ideas?
Old Sep 9, 2006 | 10:31 AM
carguy2112's Avatar
Re: '95 z not starting
Dead battery. Bad connection at batt or starter solenoid. Bad solenoid. Bad starter motor. Bad ignition switch.
Old Sep 9, 2006 | 10:35 AM
redlt1z28's Avatar
batt. is new so i'm leaning toward the starter or ign switch.thanks.
Old Sep 9, 2006 | 10:37 AM
carguy2112's Avatar
Do you have headlights and do they dim when you try and start it?
Old Sep 9, 2006 | 11:11 AM
redlt1z28's Avatar
do have headlights,but i'm alone so can't check to see if they dim.
Old Sep 9, 2006 | 01:09 PM
redlt1z28's Avatar
The lights do not dim when i try to start the car.
Old Sep 9, 2006 | 01:16 PM
carguy2112's Avatar
Starter is not pulling any power. Either solenoid or switch.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
