95 LT1 coolant crossover pipe. help please
Old Jun 24, 2006 | 10:25 AM
penicholson82's Avatar
i replaced my head gaskets, the coolant crossover pipe leaks from the back of the head? do the bolts have to line up a certain way so that the holes on the bolts line up with the pipe? i have spent alot of time putting my car back together to find out i am leaking coolant from these bolts?!?! can anyone give me some advice? thank you.
Old Jun 24, 2006 | 10:45 AM
Daniel6718's Avatar
Re: 95 LT1 coolant crossover pipe. help please
they have gaskets that are supposed to be on them!
Old Jun 24, 2006 | 10:51 AM
there is rubber gaskets inside the tube where you insert the bolt as well as on the headwhere the bolt threads in.
Old Jun 24, 2006 | 11:14 AM
Mr_Bond's Avatar
shbox FTW
Old Jun 24, 2006 | 12:12 PM
thanks bond-dave. are you saying i need to buy new gaskets? or do i need to have the bolts in just the right spot in order to line up the holes parallel with the piping?
Old Jun 24, 2006 | 01:12 PM
red 95 z28 lt1's Avatar
you need a total of 4. 2 per side, 1 between the head and crossover tube and 1 between the crossover tube and the bolt. it dosent matter with the holes in the bolt, they can face any direction
calaban
May 18, 2020 06:43 PM
MadMav
Feb 6, 2015 11:02 PM
Sandersen511
Jan 13, 2015 03:49 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Omega9
Aug 2, 2002 12:33 AM
