95 lt1 in a 93 body
Old Mar 26, 2013 | 09:08 PM
luckyou03's Avatar
95 lt1 in a 93 body
I wrecked my 95 so I purchased a good 93 body.
I swapped my
  • 95 lt1 (all 95 accessories on the motor still)
  • 95 transmission
  • 95 pcm
  • 95 engine bay wiring harness
The car will crank but it will not start.
I do not hear the fuel pump prime. I thought it might be a fuel pump issue so I shorted the fuel pump relay to turn the fuel pump on. The fuel pump did turn on after I gave it power. While the fuel pump was on, I cranked the car and still no start.
I believe it's something in the wiring such as the 12 pin obd1 port vs my my 95 had the obdII 16 pin port.
What did I miss that is different from the 93 to 95?
Old Mar 26, 2013 | 09:27 PM
oldtimeSS's Avatar
Re: 95 lt1 in a 93 body
I am going to be doing a similar swap 96 into a 94 and from what I have been told you should use your 93 computer and harness. pigtail the opti though. thats what I have gathered so far. I will be attempting the swap in the next few weeks hopefully as well.
Parts Wanted
Mar 17, 2015 11:24 PM
Jason Short
Jan 19, 2015 06:34 PM
lt1-xjs
Jan 17, 2015 07:52 PM
InfernalVortex
Jan 17, 2015 09:35 AM
