95 LT1 in 88 Iroc
Old Aug 19, 2009 | 09:01 PM
88 Iroc Project's Avatar
95 LT1 in 88 Iroc
Recently laid off So with my free time I"ve decided to FINALLY start working on my 88 Iroc which has been sitting in my garage for over 10yrs. While working on the cosmetics(preping for paint, etc..) been looking for a 350 to replace the 305tpi. Found a 95 LTI motor completely redone top to bottom-high rise, comp perf cam, etc... for a great price. Will this bolt to the exsisting 5 speed manual tranny? Want to go carbureted vs tpi?
New to the site and have'nt done any serious mods since I was about 20yrs old(I'm now 43) so ANY advice would be greatly appreciated! Obviously since I'm laid off the project is LOW budget so I don't want to let the LT1 deal get away if it doesn't require to many mods to install.
I posted this same thread in the tech section which I guess was wrong (moderators spank me as neccessary)
Thanx
Old Aug 19, 2009 | 10:02 PM
SnakeOiler's Avatar
Should bolt right in. I believe there is a ton of information on thirdgen.org, also this sticky about wiring
Old Aug 19, 2009 | 10:46 PM
thanx I'll check them out!!
Old Aug 20, 2009 | 07:52 PM
chevyowner02's Avatar
It will bolt to the T-5 but I'll bet the first or second time you dump the clutch the tranny will dump also. If you are goin carb you can get away with a lot that ppl with the efi cant. As said check out TGO a lot of good info on the LT1 swap.
dale3in98
Feb 14, 2015 12:18 PM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
capebuf
Jan 13, 2015 07:22 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
