95 impala ss??
Old May 27, 2009 | 11:01 PM
Tanner_94_Z28's Avatar
95 impala ss??
ok guys i have a 94 z28 and i bought a low mileage motor out of a 95 wrecked T/a put the motor in its not running rite mite be bad not for sure...but anyway i found a motor out of a 95 impala ss and was wondering if this would work in my 94 z28?
Old May 28, 2009 | 12:50 AM
toomchz4u's Avatar
It'll work but they aren't completely the same. The impalas, caprices, roadmasters, and fleetwood brougham have iron heads. Only the camaros, trans ams, and vettes got aluminum heads. If it bothers you then just swap the heads while the engine is out.
Old May 28, 2009 | 05:26 AM
Cam is also different. Lower compression ratio. But at least you get a vented Opti.
Old May 28, 2009 | 03:22 PM
so the cam is mildly smaller?
Old May 28, 2009 | 03:46 PM
bw_hunter's Avatar
Yes, with about 8% less lift. I don't remember the cam duration but would expect it to be less than the F and Y bodied variants.
bunker
Jan 30, 2016 08:09 PM
95chwagon
Oct 16, 2015 12:24 PM
Javi Fierros
Wheels and Tires
Jun 11, 2015 07:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
