'95 Camaro Z28 running hot
Old May 31, 2004 | 04:31 PM
warwickbass's Avatar
Well, at the moment I'm waiting to pick my rebuilt 60E up and put it back in the car. I bought it in December and it never ran hot until recently. I doubt the tranny going out has anything to do with it, but you never know. Anyway, it would gradually get hot and climb around and over 200 degrees. Upon acceleration and cruising the temp gauge would drop a little bit, so, I think it's the waterpump that might be bad. I don't know.
Old May 31, 2004 | 06:10 PM
LiT1_up's Avatar
if your car is stock your low speed fan isn't programmed to come on until your temp reaches 226*. then about 236* the other one should come on.
Old May 31, 2004 | 06:38 PM
That's not right. It comes on at 195 degrees and it never ran hot until recent.
Old May 31, 2004 | 06:44 PM
94zLT1's Avatar
no u r wrong...stock PCM turns on low fan at 228...high fan 238 (or around there) Lit1up is right
Old May 31, 2004 | 06:49 PM
Then why is it running hot now? It's probably the waterpump.
Old May 31, 2004 | 08:41 PM
95 z28 noob's Avatar
200 degrees isnt hot at all on a 95 Z's system. The cooling system is under pressure requiring it to get substantially higher before hitting boiling point. My Stock 95Z runs about 220 to 230 in traffic, soon as it hits 228-230 first fan comes on and cools it back down.
Old Jun 1, 2004 | 06:30 PM
Yeah, but it's redlined before and it has NEVER done this. So, obviously, something is wrong.
Old Jun 1, 2004 | 07:06 PM
SnakEaterZ28's Avatar
Well, sounds to me like you need to get a electricc water pump and flush your radiator . then be done with it!
Old Jun 1, 2004 | 07:35 PM
Why do YOU say replace the pump. If it's not the problem, then I just wasted a ****load of money.
Old Jun 1, 2004 | 10:24 PM
BackInBlackZ28's Avatar
If your car is heating up to 200* or so, nothign is wrong with it. Id replace the thermostat first since its cheap, and thoughroly flush the system. If you still feel the cooling system is inadequite, then do a CSI pump, cheap and you get back some HP. Thast always a good thing....
Collector Car
Dec 17, 2014 01:12 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
Mad_Ice
Jul 29, 2002 09:44 PM
