94 Z28, Water Pump Torque Value???
Old Dec 3, 2005 | 06:52 PM
DetroitGuy83's Avatar
I was torqueing down my bolts on my water pump today after replacing the gaskets, and i broke a bolt.....thankfully i was able to get the "rest" of the bolt out.
I have the Chilton book, and it says 30 ft lbs, does that sound right?
Since i had to pull the water pump back out, i discarded the new gaskets because i wasn't able to finish the job tonight, the shop closed... now, no one has the gaskets in stock, do you recommend using gasket maker??? I have the High Temp stuff.
Old Dec 3, 2005 | 09:01 PM
aarontracy's Avatar
Re: 94 Z28, Water Pump Torque Value???
id wait to get another gasket... if the gasket maker kit leaked ud end up having to replace the opti which is no fun.
Old Dec 3, 2005 | 09:43 PM
SS RRR's Avatar
huh?
Old Dec 3, 2005 | 10:18 PM
30 lb ft is correct for the water pump bolts.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
