94 z28 Good Spark No Fire
Old Mar 20, 2006 | 07:35 PM
LathersR's Avatar
I have a 94 z28 and It seems to have spark and the fuel pump turns on. It only has 62,000 miles and I have replaced the following:
Plugs
Coil Pack
Plug Wires
Flushed Out Gas Tank
Coil
Fuel Filter
I spray ether and it starts just barely. May I of followed out the new plugs cranking it over and over? I have no check engine light on and it reads no codes. Any help would be great! Thanks!
Old Mar 20, 2006 | 07:36 PM
LathersR's Avatar
Re: 94 z28 Good Spark No Fire
Did set for 3 1/2 months (winter)
Old Mar 20, 2006 | 07:49 PM
jeepz28's Avatar
mine has the same problem
Old Mar 20, 2006 | 07:53 PM
jadams94ta's Avatar
are you getting fuel to the motor
Old Mar 20, 2006 | 08:01 PM
LathersR's Avatar
Yea I can smell it... bad gas would that do it? Gas has sat about 3 months or so
Old Mar 20, 2006 | 08:05 PM
LathersR's Avatar
It might be a bizarre question to you, but it doesn't have anything to do at all the least bit with the alternator does it?
Old Mar 20, 2006 | 08:07 PM
Fuels94TA's Avatar
Check your ignition module which is under your coil.
Old Mar 20, 2006 | 08:14 PM
LathersR's Avatar
It's brand new. Could I have fouled out the plugs possibly? Wouldnt a bad ignition module stop the car from even cranking?
Old Mar 20, 2006 | 08:26 PM
Fuels94TA's Avatar
Originally Posted by LathersR
It's brand new. Wouldnt a bad ignition module stop the car from even cranking?
A bad module would just crank over but not start up.
Old Mar 20, 2006 | 08:45 PM
LathersR's Avatar
It wouldnt have anything to do with the alternator would it? The ignition module is brand new, anyway of checking it?
Old Mar 20, 2006 | 09:21 PM
Fuels94TA's Avatar
As for the alternator it would just drain down the battery, then you wouldnt have enough juice to crank it up.
Old Mar 20, 2006 | 09:32 PM
LathersR's Avatar
Im pretty sure the module is fine, any way to check it to be safe? Wouldnt be bad gas would it? Thanks for the help
Old Mar 20, 2006 | 09:45 PM
Fuels94TA's Avatar
I really dont know for sure if there is a test beside some type of electrical test to it. I was lucky to have many spare parts and swap out parts when I was trouble shooting. As for bad gas it's hard to say. Since i'm in the Navy there many time I left my cars sitting for over 6 months with the same gas in the tank when I returned.
Old Mar 20, 2006 | 09:55 PM
LathersR's Avatar
Well this was over the winter in ny and ice got on the top of the engine. I will look into another one, the gm dealer replaced it, how much do they run?
Old Mar 21, 2006 | 08:34 AM
Fuels94TA's Avatar
If you got it from the GM dealer just take it back, they might replace it. If it's still under warranty. I belive it's about $50 for the part.
