94 vs 95 engine harness question
Old Mar 1, 2005 | 03:29 PM
JACLT1S's Avatar
Does anyone know if there is a definite difference between an 94 - 95 automatic LT1 engine harness. I ordered one recently for a 95 car, but ended up with one tagged for a 94 car. Some of the connections I do not recognize, but I have never actually pulled a complete harness out of the car before to see some of the less used connections.
Jon
Old Mar 1, 2005 | 03:42 PM
Sergio's Avatar
Re: 94 vs 95 engine harness question
I can help you with it as i was with the same dillemma.
It ends up that the 94 and 95 are pretty similar but to know every detail it's best to check this link:
http://shbox.com/1/schematics_wiring.html
Choose #1 and #2 and you'll have all the info you could need.
NOTE: on #1 you can actually select/zoom on the picture to get more info about specific connectors.
#2 will show you that 94+95 are similar, the differences are between the before (93) and after (96+) years.
You can select several connectors (kinda like a flap sheet) at the bottom of the page.
I was very gratefull with this info so be sure to send the author an email.
Old Mar 1, 2005 | 05:32 PM
94red's Avatar
There is one definite difference in the harness for automatic cars but it may be hard to see. The tranny connector is the same but the 95 has one extra wire in the harness and pin in the connector, and the tranny has one extra solenoid the 94 doesn't have.
Old Mar 1, 2005 | 05:39 PM
madwolf's Avatar
Yes, the extra wire is the PWM solenoid wire. You will need it if you run a transmission 95 or newer on a 94 harness.
Old Mar 1, 2005 | 05:45 PM
Dave89IROC's Avatar
madwolf, I'm sending you a PM
Old Mar 1, 2005 | 06:26 PM
Ryan94ZA4's Avatar
One HUGE difference between the 2 if you are trying to find one for your car. The 1994 harness uses a single plug by the passenger strut tower to hook up to the body harness that runs over to the fuse box. 95's have 2 plugs on the passenger strut tower....
Ryan
Old Mar 1, 2005 | 06:32 PM
Camaro_Guru16NY's Avatar
are the pins and plugs set up the same between the two where they plug ionto the dash harness in the right side kick panel???
-john
Old Mar 1, 2005 | 07:03 PM
SSmoked's Avatar
It will need to be modified to work. When i swapped out my motor(a 94) for a motor out of a 95 i tryed to use the wireing harness from the 95 and nothing would work. I would turn the key, fuel pump wasint primeing and it wasint getting spark. I checked shoeboxe's site and the only differences i could see were thoes C100/C105 connectors. So in the end i just put the wireing harness that originally came with the car(the 94)and she started right up!
willismoons
Feb 14, 2015 08:42 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
squirrels
Jul 13, 2002 01:58 AM
