94 timing gasket on 95?
Old Sep 4, 2003 | 07:54 AM
magnumv8's Avatar
Ive got a 95 LT1 and ordered a timing cover gasket set from one of our vendors. They sent me Felpro #45953 which is supposed to be for 93-94 models. I called them and told them about it and they tell me to go ahead and use it anyway because it will work too.
I looked it up and found that I need Felpro #45956 for 95-97 LT1's. I am not sure what the difference is, but probably somthing with the opti. I will be using an electric water pump as well.
My question is... will the 93-94 style work or do I need to get the one that is supposed to be for my car.
Old Sep 4, 2003 | 08:39 AM
Smoke T/A's Avatar
They only diffrence inbetween those two kits is that the opti seal for the 93-94 car is smaller (a lot) than the one you need for your 95. I would just pick up the 95-97 kit and be done with it. Unless you are daring and are not going to replace the seals on the timing cover. drip..... ......
Old Sep 4, 2003 | 11:01 AM
madwolf's Avatar
The timing cover gasket *SHOULD* be the same, just because you can install a 95 cover on a 94 engine. The seals, like already mentioned, will be different though. Get the right set.
Old Sep 4, 2003 | 09:09 PM
magnumv8's Avatar
thanks for the replies. I didnt think I should use it, but since they said it would work I thought I better check for sure.
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
Snoman73
Nov 17, 2014 07:22 PM
