94 oil pressure sensor
Old May 29, 2004 | 09:45 AM
TrouserSnake's Avatar
Angry 94 oil pressure sensor
Ok I broke mine putting the intake manifold back on...
How on earth do you get these things off... The whole black peice plastic broke.. Just the metal peice that screws in is on there... do these have to be torqed to a certain spec?
Old May 29, 2004 | 10:17 AM
You use an oil pressure sensor socket. You tighten it until it does not leak. It uses tapered pipe threads, so you don't need to bury all the threads. Use some pipe dope on the threads (not teflon tape).
Old May 29, 2004 | 01:16 PM
well the 15 dollar oil pressure sensor socket I bought Fit the replacement sensor perfect... At least it wont fit the OEM one what the F was a matter with GM when they were making the LT1... Ive had to go buy 300 dollars worth of special tools just to install a cam
Old May 29, 2004 | 01:24 PM
ssbowtie1's Avatar
What are you talking about? They sell the oil pressure sensor socket at autozone for like $5.99. You shouldn't need any special tools for a cam install, besides the fuel disconnect tools which are ~ $5 also. If you don't have tools like torque wrenches and other misc tools then its good to have them, but they are by no means special tools. Try working on a mercedes and you'll know what "special tools" are. Good luck.
Old May 29, 2004 | 01:28 PM
Smokn '94 Z's Avatar
Lightbulb Re: 94 oil pressure sensor
When mine broke I just decided to install an aftermarket oil Pressure gauge in the car and putting the sending unit in place of the stock one... Just a thought for you to spend more money!!!
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
