94, Lt1, what size main bearings?
Old Feb 23, 2006 | 12:43 PM
DetroitGuy83's Avatar
94 Z28, 350 Lt1 Stock.....
I'm ready to replace my engine main bearings, and i'm confused because of all the different sizes they sell. What size should be fine for my stock 350?
On that note, what size replacement oil pump shaft do i need? I hope a replacement oil pump isn't this confusing to buy.
Old Feb 23, 2006 | 04:18 PM
WS Sick's Avatar
Re: 94, Lt1, what size main bearings?
If the crank is not turned just standard SBC Bearings
Really the LT1 uses the same main and rod bearings as the traditional SBC from 67 up.
Old Feb 23, 2006 | 09:28 PM
Bearings should be matched to your crank.
Old Feb 23, 2006 | 10:41 PM
Then i guess i'll be getting the standard bearings since my "crank" is stock???
Old Feb 23, 2006 | 11:29 PM
I would not even think about buying any bearings without having the crank checked with a micrometer for wear. Only then can you determine what bearings you need or if any machine work needs to be done.
Old Feb 24, 2006 | 12:58 AM
1racerdude's Avatar
The factory does strange things like .001..002 bearings in places that need them. Line hone the cam brgs after installation,ect.
So what is standard if ya don't measure it or know how to reconize the oddball's when ya see them.
A standard set of SBC bearings have a 50/50 chance of working without checking.
HectorM52
Jul 30, 2017 11:46 AM
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Camaro90RS
Jul 23, 2002 07:57 AM
