'94 dual cat. conversion
Old Aug 30, 2003 | 11:16 PM
Akshay's Avatar
How easy is it to put dual cat.'s on a 1994 z28? Like the '95 and up z28's. Is it bolt-on.
Akshay
Old Aug 30, 2003 | 11:25 PM
RedPhenx's Avatar
you will need different manifolds unless you want to do some cutting and welding.. I am pretty sure the I-pipe is the same though.
Old Aug 31, 2003 | 12:01 AM
LT1ponykilla's Avatar
Why the hell would you wanna do that. Dual cats arent good. I know, I had them. Cut them suckers off.
Old Aug 31, 2003 | 12:11 AM
Akshay's Avatar
Well, they're good for 10hp and I live in California...can't go w/out cats.
Akshay
Old Aug 31, 2003 | 12:13 AM
your saying dual cats is good for 10 hp? Thats bs!
Old Aug 31, 2003 | 01:04 AM
Got-LT1's Avatar
Actually, 1995 or 1996, starting having two cats in NY and Cali. They are rated at 285 hp as opposed to 275 in the earlier single cat versions. Don't know if that power is actually there, but thta's waht the book says.
I would not waste the time on duel cats if you don't have them already. Spend the time and money and get some headers. Besides it is against FEDERAL LAW to remove or change the number of cats on a car.
Old Aug 31, 2003 | 09:43 AM
EviLBoX's Avatar
Originally posted by crazyjim
That's cause GM likes to play around with their HP numbers every year... YOu can't honestly think running TWO cats is going to have more flow than running one. Please...
Actually the dual cat setup does flow better than the single cat. The cats are run in parallel, not series, the exhaust will flow better through two 2.5" cats vs. one 3" cat.
Even though it does flow better, it's still not worth it to convert to a stock dual cat setup. Now if you were going with aftermarket headers/cats, then it would be worth it.
Old Aug 31, 2003 | 11:09 AM
don't put a dual cat on your car, you won't pass smog in california, anything other than factory cat location won't pass unless you pay somebody off, and in that case you might as well run on ORP
I agree!!
I do not think that putting something on your car that is gonna restrict air flow is gonna add hp. Especially putting dual cats on it. Hell my car "had" dual cats. Had, is the main word there. I could tell a little difference when I chopped those suckers off.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
tdigger9899
Sep 7, 2015 10:56 AM
