93 Z28
93 Z28
Ok so i just bought a 1993 Z28 6sp about 2 weeks ago
flowmaster exhaust, airfoil, top end work, 30lb injectors, SS fuel pump, aftermarket flywheel
Suggestions for future work?
Re: 93 Z28
What do you mean by top end work? And if it has a new aluminum flywheel, did they already install a new clutch along with it. If not, a stronger clutch is a good upgrade as well as headers, cutout, cold-air kit, PCM tune, some chassis/suspension upgrades such as subframe connectors, lower control arms, panhard rod, and shocks/struts, and roller rockers.
Re: 93 Z28
By topend work i mean it was rebuilt and full tune up was done, a new clutch was installed but i was not the owner and i do not know if it was a stronger one or not, all new gabriel suspension except springs
Re: 93 Z28
www.jegs.com, www.summitracing.com, www.thunderracing.com to name a few, or maybe even certain exhaust shops can hook you up.
Re: 93 Z28
thanks any other suggestions, Oh yea i have a 180 temp stat already also
the kid before me has a friend with the new gto and supposedly he's stayed side by side with it
Re: 93 Z28
Re: 93 Z28
Goal wise, well i go to school in florida (im from upstate NY not many high performance cars here) so im trying to get in the 12s id really like to do the work for 11s but i dont think i have the money
Re: 93 Z28
Does it have a Cold Air Induction (CAI) yet? If not do that, get some headers, a cam , and a tune from Alvin at pcmforless.com. That will get you deep in the 12's if you can drive. Be careful with gearing in a 93 M6 car. They are a different breed...that have deeper gearing in the trans than the 94+ cars. This link will tell you a lot of the differences between the 93's and newer f-bods. http://www.speeddensity.org/showthread.php?t=32
Re: 93 Z28
yea i know about the gearing i unfortunatly have 2.73s right now which is ok because its good for highway gas but bad because of acceleration i was gonna get the stage 2 jet chip is that good or no?
Re: 93 Z28
Re: 93 Z28
Stock is 180, get a 160 and a tune to have the fans come on at a lower temp. And as for a pretty much stock Lt1 hanging with a 05 GTO LS2.....I don't think so.
