93 trans line pressure
Old Mar 28, 2004 | 05:32 PM
WhoomWhaatWhaah's Avatar
How can I adjust my shift points or chang my line pressure in my 93 4l60 camaro?
Old Mar 29, 2004 | 08:30 PM
anyone?
Old Mar 29, 2004 | 08:33 PM
sc93's Avatar
shift points in a 4L60 (aka 700r4) are changed using different weight springs in the governor gear assembly. This is found on the drivers side near the tailshaft under the ~ 3" round metal cap on the side. You will most likely have to drop the tranny to get the governor out all the way.
Old Mar 29, 2004 | 08:34 PM
Danno's Avatar
AFAIK, the only way to change your line pressure on a 700R4 (4L60) would be with something like a transgo shift kit, where you're actually modifying the valve body. But, I'm definitely not as well informed on trannys as I should be, so ???
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
jackpawt883
Feb 26, 2015 09:04 PM
Jul 4, 2005 05:00 PM
