'93 rough idle when cold
Old Aug 22, 2003 | 08:59 PM
Ryan94transam's Avatar
A friend's '93 Trans Am will idle very rough at about 400 rpm's when cold, and the exhaust smells very rich. It is fine once it is warmed up. ? Midas told her it was her fuel pressure regulator, which I argued with them about, and sure enough she still has the problem after they replaced it. Now they say she has to replace both coolant sensors, her water pump, and the optispark.
Any ideas as to what would make it do this when cold, but fixes itself once warmed up? It is dumping way too much fuel during idle. As far as I know, nothing except the plugs and wires have ever been changed on the vehicle. It has 105,000 or so miles on it. The fairly new plugs are very fouled now that it is running so rich when you start it.
Old Aug 22, 2003 | 09:04 PM
KeVMaN's Avatar
eh.. mine does the same thing. 93's don't have a MAF so i think they kinda have trouble with that. I was thinking o2 sensor? but eh whatever.
Old Aug 22, 2003 | 11:35 PM
Got-LT1's Avatar
Check for leaking fuel injectors! I just had that problem on my 93 and failed smog becuase she was too rich.
BTW a local midas wanted to change my waterpump when the were going to fix the injector, said it was in the way. I was like . The bad injector was on the #5 cyclender (3 back drivers side) the wp is nowhere near there! And they wanted ~$900. Needless to say I left got the injector from a chevy dealer and put it in that night. only cost $120 and took 1.5 hours. Midas said 9 hours. Be carefull with them.
EDIT: they were also after the opti, which has no problems.
Old Aug 23, 2003 | 12:28 AM
SantaCruz163's Avatar
If you had a leaking injector you'd probably have a bit more of a problem. You'd probably have a fire.
Old Aug 23, 2003 | 05:29 PM
Got-LT1's Avatar
Mine was leaking for a little while. When I say leaking, I mean the valve inside would not close all the way, causeing fuel to be shot into the exhaust, not leaking as in leaking outside onto the engine. Hope that clears that up.
markzzzz
May 8, 2015 09:21 AM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
TrouserSnake
Jul 29, 2002 11:24 PM
