93 obdI coversion
'93s can't use the LT4 KM, '94-'97 cars can, so if you were to swap a '94-'95 computer in there, you can use the LT4 KM and still be obd1 and be able to use a programmer instead of burning a chip. Not sure if it is worth doing or not. I know you will have to get a Mass air sensor, don't know what other sensors there were after 93, maybe a crankshaft positioning sensor.
I swaped my 93 to a 94 type PCM. It was not nearly as hard or expensive as people make it out to be. I did it for the ease of tuning for my new motor. It drives much better than with the 93 setup. For a motor with just the basic bolt ons, I would say it's not worth it.
Dan K
Oct 28, 2002 05:27 PM
Dan K
Aug 3, 2002 09:12 AM
