93 lt1 can't be tuned at local dyno shop?
Old Jul 1, 2011 | 12:07 AM
dennis5374's Avatar
Im seriously stumped here. The only dyno shop within 200 miles say they can't dyno tune my car? What should i do about this? My car will be done tuesday and i can't even get a mail order from pcmforless cuz they're closed till the 4th? What other options are available as i want my car running right asap. Also how do i datalog my car so i can send the info too pcmforless or whoever too get the best results?
Old Jul 1, 2011 | 06:28 AM
RamAir95TA's Avatar
Re: 93 lt1 can't be tuned at local dyno shop?
93s are a bitch to tune because the EPROM needs to be burned each time. You may want to consider converting to a 94+ OBDI PCM that is flashable.
Old Jul 1, 2011 | 08:05 AM
grabbem88's Avatar
Since this came up can you use a 94 pcm without changing harness? Or do you run into mass air issues?
Old Jul 1, 2011 | 12:22 PM
dennis5374's Avatar
So could i datalog the car at the dyno then send the info too pcmforless? What about lt1 pcm tuning?
Old Jul 1, 2011 | 12:24 PM
dennis5374's Avatar
I wanna let this thing rip so bad. I put way too much money into it too have too wait weeks for it to e right
Old Jul 1, 2011 | 06:26 PM
RamAir95TA's Avatar
You don't have a PCM, you have an ECM. To change the tune a new chip must be burned each time. For your combo you MUST start with a mail-order tune/chip. Ideally you need someone who can dyno-tune ECMs and can burn them on-site.
Converting to 94+ requires PCM, harness, a MAF, and a bunch of other things, but for a tuning perspective it's worth it.
Old Jul 1, 2011 | 07:32 PM
lt1-xjs's Avatar
You should have ordered your base tune weeks ago from Alvin. Now all you can do is wait and enjoy the holiday.
Old Jul 1, 2011 | 11:47 PM
dennis5374's Avatar
I have a bolton tune from him but don't wanna run it on this combo. Should i remove the chip i have when i run it at first? Or take the chip out and wait for the new one?
Old Jul 1, 2011 | 11:51 PM
dennis5374's Avatar
Yeah. Im talking bout the site called lt1pcmtuning. They do eprom chips also
Old Jul 2, 2011 | 07:53 PM
lt1-xjs's Avatar
Wait for the baseline tune for the set up you have now.
Old Jul 2, 2011 | 11:03 PM
Colin's Avatar
I'm currently trying to get my Moates AutoProm working correctly. It allows you to real-time tune your engine and then burn a chip for the engine using the AutoProm. That chip is then inserted into the G1 adapter in your PCM.
http://www.Moates.net
Old Jul 3, 2011 | 12:22 AM
MikeGyver's Avatar
93's are poo. Look to swapping in a '95 pcm, makes things very easy.
Old Jul 3, 2011 | 09:35 AM
mrmint69's Avatar
He never even used any of my datalogs. You can fine tune it, but he is very good at getting it right the first time. The less the mods, the easier it is to get it close to perfect.
Old Jul 3, 2011 | 10:05 AM
Colin's Avatar
MikeGyver,
How so? Because you can use LT1Edit? Or you have SEFI? OBD-I LT1 runs just fine but it takes a bit more effort to tune. I'm happy with mine but struggling to get it running for the first time. The AutoProm is a nice unit and cheaper to purchase and run than LT1Edit.
Old Jul 3, 2011 | 10:10 AM
dennis5374's Avatar
When my car had all boltons i got a custom tune from pcmforless. My cel stayed on and honetly i did not notice a bit of difference before or after. What is involved in swapping a 95 pcm into my car? What's needed for parts? Anyone know a shop in new york that can dyno datalog and burn chips for my car?
