9.78 lt1 vid
Old Nov 8, 2009 | 02:58 PM
  #16
1-fuel's Avatar
it only ran 11.50 with a 1.77 60 ft in the heat......the converter is to small for the heads and cam,and the motor is detuned or a 300 shot.im shure it would run a 10.90 with the right tune and converter.
Old Nov 9, 2009 | 12:56 PM
  #17
T/A lt1's Avatar
Nice man what rpm are you crossing at 136mph? Are you running a progressive are not spraying off the brake b/c it looks like it's leaving then the n2o comes on. Still very impressive. Later
Old Nov 9, 2009 | 04:46 PM
  #18
1-fuel's Avatar
i go trough around 7200 rpm. and i leave on the foot break,and my progressive was set for i think 69 % and ramp up to a 250 shot in .7 seconds
Old Nov 10, 2009 | 07:21 AM
  #19
T/A lt1's Avatar
What engine mangement are you running, stock PCM? Sorry saw on LS1tech that u are running stock pcm well how do you get it to go to 7200? Mine only goes to 7k before it starts popping? I am going to put a set of 3.73's in to see if my car will cross when I turn the n2o on. How many rpm are turning it before you shift on motor and n2o?
Old Nov 10, 2009 | 11:20 AM
  #20
Stainless Works's Avatar
Nice Job 1-Fuel.
Old Nov 10, 2009 | 04:37 PM
  #21
1-fuel's Avatar
im going by what my auto meter tack says.it may not be accurret. some times i here some poping when im in 1st gear around 6600 rpms. i dont know if the tack is slow or im getting vavle flot.
Old Nov 10, 2009 | 04:38 PM
  #22
1-fuel's Avatar
yas stock pcm
Old Nov 13, 2009 | 02:25 AM
  #23
SPEED#1's Avatar
That car is flyin, holy hell.
Old Nov 13, 2009 | 07:31 AM
  #24
T/A lt1's Avatar
Fuels car is moving and there is alot left in that setup also. I plan on setting my n2o up with one stage 100hP NX to come off the T-brake, then have the second stage 200HP on my digiset, to come on between .3-.5tenths. But not going to spray both kits at the same time. I may try one stage this weekend just until the 1/8th mile. Later Clint
Old Nov 13, 2009 | 08:28 PM
  #25
1-fuel's Avatar
holy crap..........is that your green t/a in the gm article...i used to read about your car all the time in the mag and wishing, i would be as fast as you some day........
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Chris Ja
Sep 14, 2002 06:10 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Ude-lose
Jul 31, 2002 02:11 AM
