9.68 video in my 6speed is up on BMR's site!!!
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
http://www.bmrfabrication.com/FeatureCars/Tanner.htm
if you check out the above link you can see that badass A.R.E powered beast run down the track!
thanks to Wade and Brett!
1.27, now THAT is the ****!
Taner-
I am in the process of a T56 build for my car, I am croing the gears and such, and gonna run a Viper output shaft. care to share what you are doing?
Taner-
so you have the fastest 6spd F-body? or just the fastest 6spd
although i'm sure you dont want to give away all your secrets-
what kind of nitrous are you spraying (and how)
what heads
what cam specs?
congrats man, awesome car
what heads
what cam specs?
it was a fat 300 shot, nice and safe.
A.R.E freshened up the motor, i had 3 lifters go out on me last year, i made that run with 13 good lifters
Wade jammed a nitrous friendly cam in there
wade even came to the track on saturday, very cool! helped stage me where i needed to be.
trey,
i believe it is THE fastest 6 speed, 9.82 was the old record by an MTI vette, mind you that stood for a while. RomanSS had the f body record for over a year. Agostino can add another first/ record holder to the growing list they already have. I believe i am the first confirmed lt1 6 speed in the nines??? correct me if i am wrong.
i also brought the weight of the car down to 3425ish in race mode tack on an extra 50 or so pounds with the stock seats in street mode. also finally added k frame, hals front and rear. now i am trying to dial the car back in! car weighed close to 3650 in race mode last year.
TS95Z,
600 shot! holy sheeeeit! i am assuming a progressive controller with come into play somehow or is it a 2 stage.
i can't wait till the North vs. south event at bowling green event may 31st! i know i won't win but i hear the track is awesome!
trey,
TS95Z,
