70mph RPMs with 3.73 (a4/m6)
Old Oct 25, 2003 | 05:49 PM
Seal's Avatar
Just trying to get an idea, and compare...
i'll be getting 3.73s, so i wanted to know the cruise RPMs at 3.73s on a4?
also 4.10s at 70 too please
even better if u guys can tell me m6 RPMs, so i can compare
i assume 2500-2600@70 with 3.73s
and 3000@70 with 4.10s?
no clue about m6 tho
Old Oct 25, 2003 | 06:01 PM
z2894convertible's Avatar
I am not for sure on the RPM's at 70, but I run 3000 at 80 in an A4.
Old Oct 25, 2003 | 06:44 PM
DB75's Avatar
2600 @ 70mph and 3000 @ 80mph for the 3:73s. Not sure about the 4:10s though.
Old Oct 25, 2003 | 06:53 PM
Compare easily with this:
http://www.f-body.org/gears/
Old Oct 25, 2003 | 07:23 PM
Wild1's Avatar
At 80 MPH, I'm at 2400 RPM with a M6 (4.10s). At 70 MPH, more or less at 2250 RPM.
4.10s
Old Oct 25, 2003 | 08:09 PM
I have refered to that before and it is not correct. According to it I should be at 88 mph at 3000 RPM's .
Old Oct 25, 2003 | 08:34 PM
NewbieWar's Avatar
yea according to that, i should be goin 100mph at 3000rpm's in 4th in my A4...
but its more like 80mph
Old Oct 25, 2003 | 08:42 PM
Wild1's Avatar
Try this link Chrisman - California Gears
Find MPH
Old Oct 25, 2003 | 08:53 PM
Every online calculator I have been to, including the one I linked to and the one on this forums sticky post, say the same thing. So I guess they are all wrong?
Old Oct 25, 2003 | 09:39 PM
Wild1's Avatar
Despite the drive ratio and other variables, there isn't a variable for parasitic losses due to the A/T condition or the clutch slippage on a M/T. Anothor area of loss is the differential itself. Some diffs require more energy than others (ie 9-inch vs. 12-bolt). Those variables aren't part of the equation.
Old Oct 26, 2003 | 12:15 AM
RE AND CHERYL's Avatar
Cool
What does that have to do with RPMs while cruising along. Clutch slippage and looses through an automatic transmission are a nonissue in this instance. While you are cruising at say 80 mph there is no clutch slippage and the torque converter is locked up so there are no losses through the transmission either.
Old Oct 26, 2003 | 04:07 AM
MentalCaseOne's Avatar
Using 2.73 as the baseline then....
engine will turn:
3.23 = + 20% more RPMs
3.43 = + 26% more RPMs
3.73 = + 40% more RPMs
Is this correct? After looking at this I am more inclined to go for the 3.43s. I think I have just made up my mind...
Old Oct 26, 2003 | 06:24 AM
2cub49's Avatar
3.73's are more fun for acceleration but if you do any regular highway driving over 70 mph get 3.42's.
Old Oct 26, 2003 | 06:14 PM
I am starting to think my tach is off by about 500.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
