700R4 Won't shift!
Old Apr 13, 2004 | 10:14 PM
BDBRIZ28's Avatar
Angry 700R4 Won't shift!
I have a 93 Camaro Z28 with a 700R4 automatic transmission. A few weeks ago the transmission would not shift out of first gear. So I checked the transmission fluid and noticed it was a little low. I put some in and it ran fine for about a week. Now when i drive it will not shift out of first until around 3400 - 3600 RPM. And when it does finially shift it is very very hard even at very low speeds. Checked the transmission fluid and it is not low. I am not sure what could be causing it. Any help would be appreciated. Thanks
Old Apr 13, 2004 | 10:27 PM
badblackta's Avatar
mine did something similar. It would shift from first then to second then would it would shift into third it would rev up like it was in neutral. I ended up getting it rebuilt.
Old Apr 13, 2004 | 10:57 PM
speedracer93z28's Avatar
just mess around with your TV cable on your throttle body to change the shift points, mine did the same thing
Old Apr 13, 2004 | 11:01 PM
95lt1&99ls1's Avatar
Just don't mess with it to much or you will burn up your tranny
Old Apr 13, 2004 | 11:34 PM
WhoomWhaatWhaah's Avatar
This site helped me a lot
http://www.tvmadeez.com/
Old Apr 14, 2004 | 12:00 AM
KeVMaN's Avatar
I had the exact same problem. I bought a new transmission about a month ago.
bowtieboy95
Jul 1, 2015 06:49 AM
PCLZ28
Apr 29, 2015 11:56 PM
Cam's maro
Jan 30, 2015 09:21 PM
Cam's maro
Dec 28, 2014 09:30 AM
