7/16ths studs for roller rockers
Old Jun 3, 2005 | 01:26 PM
LT1OWNZ's Avatar
What needs to be done to run the 7/16s studs for roller rockers over the 3/8? Do the holes have to be drilled/tapped? Or are the ARP studs still 3/8ths on the bottom and 7/16ths on the top?
Im looking at comp pro mag 1.6 NSA rockers.
Old Jun 3, 2005 | 01:41 PM
Mr_Bond's Avatar
Re: 7/16ths studs for roller rockers
You'll need the 7/16 rocker arm. The ARP are 7/16 on the bottom. 3/8 is the smaller top. 7/16 is the bigger top. That all
Old Jun 3, 2005 | 01:50 PM
LT1OWNZ's Avatar
Ok so my 7/16ths rockers im getting and the ARP 7/16s studs will screw right in and be good to go then?
If what im thinking your saying its a 7/16ths hole in the head, and stock it was just smaller on the top half of the rocker stud? 7/16 in the head 3/8 on the rocker? Correct?
Old Jun 3, 2005 | 02:00 PM
cliff929's Avatar
Yes they will. You did get the guide plates also to?
Old Jun 4, 2005 | 12:04 AM
1 Nasty Bird's Avatar
Im thinking GMPP guide plates are best from what i hear on here. Id get those and im at a toss up with springs. LT4s are nice and cheap, but i want to go up to the LE2/3 setup before the summers over. Can i get those springs now or do they require mchine work to install? Just dont wanna do it twice if i dont have to.
Old Jun 4, 2005 | 12:11 AM
stereomandan's Avatar
The LT4 springs are so cheap, get them now and then get the LE stuff later. I wouldn't want to break in the springs on the stock lift, and then try to break them in again at the LE cam lift #s.
Dan
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
