7/16 rocker arm studs..which ones??
Old Aug 24, 2007 | 04:47 PM
marshall93z's Avatar
There seems to different lengths and I have read that you don't want the long ones because it'll bottom out in the head. Can someone give me the correct part numbers for them?
Old Aug 25, 2007 | 01:28 AM
a walker's Avatar
ARP # 134-7103 and 234-7202.
Old Aug 25, 2007 | 08:44 AM
wrd1972's Avatar
I got the Comp Cams ones and had to grind some length off, they were running into the bottom of the heli-coil legs. Seems like I removed almost 1/8" but there is still plenty of thread.
Old Aug 25, 2007 | 08:54 AM
Vicious95Z28's Avatar
My comps were made by ARP, I have guideplates and mine fit great.
Old Aug 26, 2007 | 01:47 PM
Thanks man! I take it the Pro Series (234-7202) is just stronger....since the specs are the same?
Old Aug 26, 2007 | 03:45 PM
a walker's Avatar
Yep, you got it.
Old Aug 26, 2007 | 07:17 PM
Cool.
When should the tougher ones be used?
Old Aug 26, 2007 | 10:46 PM
a walker's Avatar
I'm no professional when it comes to fasteners, but I would think the high performance series studs are plenty strong enough for the average street/strip car, but if you have the money, why not get the pro series? Its better to have and not need, than it is to need and not have
Old Aug 26, 2007 | 11:42 PM
I live by those words!
Old Aug 27, 2007 | 12:10 PM
Kevin Blown 95 TA's Avatar
You can throw a machine bushing (ground flat washer) under those if you need to - assuming you're not using guide plates. As long as you have the adjustment range for the rocker and the posilocks and set screws all have enough threads to fit right. I fretted over this for a while when I built my engine cause it was near impossible to measure everything and order the right ones, but I got lucky and guessed right, LOL.
Old Aug 27, 2007 | 08:15 PM
I'll be running guideplates.
Old Aug 27, 2007 | 08:25 PM
Well , max strength on a threaded fastener into steel is usually about 1.5 x dia so anything close to that will work.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
