7/16"-20 hardened nut needed or not?
Old Apr 19, 2004 | 07:48 PM
30thannZ28's Avatar
I'm trying to re-install my crank hub and I wanted to know exactly HOW neccessary the 7/16"-20 hardened nut was when using the homemade tool to install the hub. I can't get one locally, so I would have to order one. Can I just use some regular nut, or is that the dumbest mistake to make when putting the hub back on?? I have a grade 8 strength threaded rod, a piece of pvc pipe, and some washers to make my hub install tool, but I'm just missing the nut. Please chime in if you have used a crappy home depot nut to install your hub. thanks a lot!
Old Apr 19, 2004 | 08:33 PM
gb95zconv's Avatar
Give the lower grade a try......if it strips out you know youll need the grade 8. Might want to get 2 or 3 of them.
Old Apr 19, 2004 | 09:54 PM
leadfoot94's Avatar
Hmmm. Any local Hardware store should carry one (I know mine does). Most of them carry Grade 2 all the way to Grade 8. Just get the hardest grade you can.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
