6psi at idle
Old Mar 13, 2004 | 11:50 PM
hvyss's Avatar
6psi at idle
Guys,
I was driving the imp the other day and the car died at a light. I restarted it and when I got to the next light I happened to look down at the oil pressure gauge I had 6psi at idle (975 idle) . Above 2000 rpms I have 50psi but at idle or lower than 2000 rpms the pressure is extremely low. Any ideas? Spun bearing? I hope to hell not. Motor has less than 2000 miles on it.
HVY SS
Old Mar 14, 2004 | 12:56 AM
CamaroBoy96Z28's Avatar
I get around 10 psi or so at hot idle and 50 psi at WOT. Thats what my gauge says though, so it could be wrong. Check if the pickup fell off or hook up a mechanical or electrical gauge and see what that says.....does the car run rough or feel like its starving for oil? If not, then the oiling system is probably not the issue.
Old Mar 14, 2004 | 07:08 AM
hvyss's Avatar
The car runs fine. I have an IAC issue at idle. I get alot of idle surge. But no knock or noises. The only thing is if I turn the car off and let it sit for 10-15 minutes it turns over slow like its really tight but does start. Bryan Herter is going to tune out the idle surge. And when I changed the oil there was a considerable amount of metal on the magnet of the drain plug.
HVY SS
Old Mar 14, 2004 | 07:17 AM
hvyss's Avatar
HVY SS
Old Mar 14, 2004 | 08:09 AM
BadAssed93Z's Avatar
my car had the same oil pressure issues, and when i opened her up the pick up was just laying in the oil pan.
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
