Was 6k to far?
Old Nov 27, 2006 | 02:25 PM
frankthetank078's Avatar
Was 6k to far?
i ran into a srt10 truck on the way to school to day. to make a long story short i wasent paying attention at hit around 6.2k in the car after that there is a weird clinking noise under the car so i jacked it up on one side and started it up... the noise is comming from right behind the oil pan where the oil drips outs... it is silver in color and has a little bend to it and up in there is where the noise is comming from. The clinking doesnt have a pattern to it and happens spontaniously. What could this be? thank you
Old Nov 27, 2006 | 02:35 PM
razor02097's Avatar
So let me get this straight...
You ran into a truck as in you got in an accident?
"6.2k" is 6200 RPM or 6.2 KPH?
"The noise is coming from right behind the oil pan where the oil drips outs” You are speaking of the drain plug?
If the car is damaged you might check the fans behind the radiator if they are obstructed and they kick on you will get a clicking noise.
Sorry for my ignorance
Old Nov 27, 2006 | 02:47 PM
JoeliusZ28's Avatar
i think he might mean he raced an srt10
Old Nov 27, 2006 | 02:50 PM
SantaCruz163's Avatar
Well, silver oil is never a good sign....
Old Nov 27, 2006 | 03:07 PM
razor02097's Avatar
That makes more sense
nether is a dent on the side of the oil pan...
Old Nov 27, 2006 | 08:25 PM
when i said ran i ment race and i took the aluminum shield off and it was a chunck of metal about 3 inches long and flat right where the flywheel is but the cars running fine again. Im taking it to the tranny shop tomorro to see whats up
Old Nov 27, 2006 | 08:45 PM
93formula's Avatar
did you atleast win?
Old Nov 27, 2006 | 08:47 PM
Matts1994Z28's Avatar
Thats not good...
Old Nov 27, 2006 | 08:52 PM
reamo04's Avatar
6200 is nothing, my car revs to 6700 or so daily...
Old Nov 27, 2006 | 09:29 PM
doug1105's Avatar
if it's a 6 speed, that sounds like one of the fingers off the pressure plate breaking loose.
my bad-just saw it's an automatic
Old Nov 27, 2006 | 09:37 PM
reamo04's Avatar
maybe break a tranny mount?
Old Nov 27, 2006 | 09:50 PM
lt11997's Avatar
Take a picture of it and post it up so we can give you a better answer.
