Is 6500 RPM's rev limiter set about right?
Old May 29, 2006 | 02:09 AM
RUFST's Avatar
Question Is 6500 RPM's rev limiter set about right?
What i'm doing to it is already in my sig. b/c it's in progress right now and was wondering if that's about right for the hotcam b/c i've read and most ppl drop off at about 6200 i think seems like
what would be about redline or how would you figure it out after doing this
also answer me this if possible does anyone know what compression i will be after the install and what it was stock, i thought stock was 10:1 but not sure
thanks
Old May 29, 2006 | 02:12 AM
Javier97Z28's Avatar
Moderator
Re: Is 6500 RPM's rev limiter set about right?
I think it's too high.. 6200 would probably be better.
I haven't seen a hotcam dyno sheet in a while, but I'm pretty sure it quits pulling well before 6500 rpm
Old May 29, 2006 | 02:15 AM
madwolf's Avatar
6500 or 6600 is good. Ideally, you want to shift about 600 later than where peak power occurs for best track times. A couple hundred RPM more than that just assures that you won't accidentally hit the rev limiter.
Old May 29, 2006 | 02:16 AM
Moderator
I'm sorry.. I read it as a shift point.. not rev limiter...
Should be fine, but I'd shift lower than that either way...
Old May 29, 2006 | 02:26 AM
RUFST's Avatar
oh sorry might not made myself very clear.......yes i'm going to shift alot sooner than 6500 i'd say but don't want to blow it if i miss which i hope to not do but stuff happens ya know. I appreciate it guys i thought that would be about right for the limiter
wonder what the redline will be in actual though? and what compression
Old May 29, 2006 | 12:09 PM
Sweetred95ta's Avatar
What are you doing that may change the CR? The stock CR is 10.4:1. If you use thinner head gaskets and mill the heads, you can raise it to around 11:1, I think anyway. Hope this helps.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
armedtrigger
Feb 24, 2015 08:30 PM
Nostang 96z
Aug 31, 2002 12:01 PM
