52mm or 58mm
Old Feb 7, 2004 | 05:43 PM
  #16
leadfoot94's Avatar
AS&M 54mm TB... the best of both worlds.
Old Feb 7, 2004 | 06:14 PM
  #17
Gripenfelter's Avatar
I tried a friend's 58mm TB last yr. It seemed to have less throttle response than the 52mm. Which produces more hp? Dunno.
Old Feb 7, 2004 | 07:21 PM
  #18
Antz97ZNJ's Avatar
52 is more then enough
Old Feb 7, 2004 | 10:56 PM
  #19
93Z286Speed's Avatar
close to same setup going with holley 58mm... i was told my lloyd that if i wanna get the most outta my heads cam car 30# injectors and a 58mm tb is what i want
Old Feb 7, 2004 | 11:57 PM
  #20
GT40MkI's Avatar
unless you are pushing some serious hp 500+ stay with stock
i oull 122mph threw the traps on a stock tb
Old Feb 8, 2004 | 12:10 AM
  #21
S.J.S.'s Avatar
yeah.....I wouldn't go no more than a 52mm. I was told by Holley that the 52 would be more than enough for my set-up as well.
Hey Banester. I think you should drop down to a 40mm you backwards ****.
Old Feb 8, 2004 | 11:34 AM
  #22
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
stick with the 52 unless your going to go big (>450hp or >350cu in). denny will be the first to come up with the break point i bet i bet....
david
Old Feb 8, 2004 | 11:47 AM
  #23
Denny McLain's Avatar
I'm gonna try anyway.
Just ordered all the parts to redo my bottom end a couple of weeks ago with everything getting balanced this week and am working of a set of new heads. As soon as eveything is together, I'll take the combo to the dyno and do final tuning. Once tuned, I'll borrow a 58 TB and see what happens.
I've learned to be conservative in my estimates but have made as much as 466 rwhp in the past with other combo's. I expect this one to be anywere between 425 rwhp to perhaps as high as 450+. Whatever..... ??
This TB thing with everyone guessing needs some real answers. Screw this theory stuff...... it where the rubber hits the road that counts.
I've owned a stock 48, 52, 58 and a monoblade and don't know if any of them made a tinkers damn of a difference. As mentioned, going to a 58 from a stock 48 on a car making 331 rwhp made no difference.
The 466 rwhp run was with a 58 mm TB. Went to the monoblade and ran into other problems throwing everything off or I've have an exact answer on that one.
RUENUF
Mar 13, 2016 03:37 PM
truecontr3
Oct 11, 2015 09:30 AM
95blkss
Sep 22, 2015 03:18 PM
colts0455
Sep 2, 2015 12:41 PM
colts0455
Jul 24, 2015 04:51 PM
