52 TB or 58TB?
Old Sep 21, 2003 | 03:10 AM
BiGGinZ's Avatar
52 TB or 58TB?
I want to eventually have a full exhaust, cam, you know that sort of thing in the next 2 years or so. What TB should I get, 52 or 58?
Old Sep 21, 2003 | 04:14 AM
jkipp84's Avatar
If all you're doing is the cam, etc. (no heads), your stocker will do just fine. In fact, plenty of folks just stick with it for heads and cam and have great #'s. I'd put the TB $$ towards the build up.
Old Sep 21, 2003 | 06:16 AM
madhatter's Avatar
go for the 58 if you do it. I don't think it is worth the money myself. But if you do it go 58. I personally have seen results form a 52 to a 58 on a bolton car. If i hear one more person say that it is too much, I will personally come out there and bitch slap them. Unless you can show me proof of your calim that it would be too much, don't post.
Old Sep 21, 2003 | 06:40 AM
BlueCamaroZ28's Avatar
Hay hay hay.. Show us your proof that 58 TB is better than 52. With minor bottom and top part modifications, I don't think it is worth going higher than 52mm TB. Remember larger TB will slow down your air velocity in the intake and you will loose some bottom end power. Just my 0.02.
Old Sep 21, 2003 | 12:00 PM
GUMP's Avatar
There is really no need to go to a larger than 48mm throttle body with the changes that you are planning. If you are N/A the factory throttle body is good well into the tens. At that point the head flow becomes more of a limiting factor than the throttle body (Stock LT1 castings).
If you see a gain when going to a larger throttle body it is probably that you were running too rich before. LT1 Edit would be a better buy.
Good Luck.
Daren
Old Sep 21, 2003 | 02:25 PM
NOMAD's Avatar
Cool
I have yet to hear one single person using one of my 52mm throttle bodies say they lost power. From stock cars to 383 strokers.
Atljar is supposed to be giving me some track results here very soon of a back to back run. If not, i'm doing it next time I go to the track if I can round up some slicks.
-Shannon
Old Sep 21, 2003 | 05:22 PM
madhatter's Avatar
Nomad,
are you still doing the throttle bodies? what is the price and the options? I have a friend interested...
back to back runs between a 52 and 58 on a 96 impala with minimal bolt ons. .2 in the 1/4. same 60' . Not sure if he posts on here or not, but 4DRHTRD on AZSR.com, AZFBA.com. As soon as I am doneith my project, I will gladly do a dyno of a 48, 52, and then a 58.
Old Oct 7, 2003 | 01:58 PM
atljar's Avatar
-Shannon
Its comming, I promise, i know i have been saying that for awhile. I still havent had more than 2 passes on the same day since i got the TB a few months ago.
Old Oct 7, 2003 | 02:19 PM
Type_O_Negative_1320's Avatar
You made two passes the day you blew my car up, fokker!
Old Oct 7, 2003 | 02:33 PM
atljar's Avatar
Yup, one in my car, and one busy blowing up that 383 in yours Next time it would help if you bought fuel injectors that worked.
http://www.gcfba.com/ikon/uploads/po...boom_small.JPG
qnitro
Mar 10, 2010 12:50 AM
97faceoff
Jan 4, 2009 10:57 PM
camzaro28
Feb 27, 2007 08:20 PM
superirocz
Jan 25, 2007 07:56 PM
kirschman
Nov 25, 2005 10:27 PM
