51cc chamber would make what difference on stock/na engine compression?
Old Apr 16, 2006 | 03:23 PM
94 CAMRO Z28's Avatar
Looking to find out how much of a difference heads with 51cc chambers would make on stock compression. I plan on using the thinner Impala gaskets to bump compression back up a little. Im looking at a set of heads/intake right now but I do not intend to supercharge/turbo, nor will anything be done with pistons for now to bump compression back up.
Aaron
Old Apr 16, 2006 | 03:31 PM
MeanGreen97Z's Avatar
Re: 51cc chamber would make what difference on stock/na engine compression?
51cc and a .026 gasket are going to make a big jump..... try the compression calculator.
Old Apr 16, 2006 | 03:34 PM
12.1:1 .... that's a little steep my friend.
Old Apr 16, 2006 | 04:08 PM
I guess Im a little confused. I thought the stock chambers were 48, and by increasing the chamber size to 51, wouldn't that lower my compression?
Aaron
Old Apr 16, 2006 | 04:57 PM
96capricemgr's Avatar
Stock is more like 54 or so they vary, 51cc takes some milling. I am going to a 51.3 cc chamber with the Mr. Gasket .026 and am coming out with 11.5+ on a stock shortblock. See you at WIR after it is all back together, if the tuning goes well the May 5th RSD might be the first pass for the new combo.
Old Apr 16, 2006 | 07:52 PM
Cool sounds good, I will see you there. What kind of heads are you going with. Stock castings? Who are you having port them?
Aaron
Old Apr 16, 2006 | 09:39 PM
Chopstix's Avatar
I am running a 48cc chamber...with stock short block and stock thickness gasket I was ~11.5:1
Old Apr 17, 2006 | 03:36 PM
Grease's Avatar
I had my heads cut down to 50.5cc combustion chambers and I used Felpro 0.039" head gaskets. It came to somewhere around 11.86CR on the stock shortblock according a compression calculator. This setup lasted 2 years shifting at 6800rpm. The engine cant take it, just make shure you run good gas in it all the time.
Old Apr 17, 2006 | 05:26 PM
You guys going smaller on the chamber and using the Felpro or stock gaskets are doing it wrong. The ONLY way I would consider using the Felpro gasket would be on a block that is zero decked or VERY near zero. If you don't understand why I say this do a search on "quench" very important when trying to safely run high compression. Stock the pistons are .015-.025 down most being closer to the .025 number add a .026 gasket like the Mr. Gasket or Victor Rienz and you still have a far from optimal .051 quench thicker gaskets just make it worse.
InfernalVortex
Jan 17, 2015 09:35 AM
95chwagon
Jan 13, 2015 09:19 PM
Rich_z28
Sep 8, 2002 12:00 AM
$hawn
Aug 28, 2002 09:09 AM
