5.7 or 6.0 rods for my 383
Old Jan 3, 2004 | 07:23 PM
97Z-M6's Avatar
if there any advantage from using one form the other. i know a kit with using 5.7 rods and 1.425 height pistons is cheaper than 6.0 rods and 1.125 pistons
just wondering.
the machinist told me that the 6.0" rods produce more torqe because of the angle that the rods are at when the engine fires.
Old Jan 3, 2004 | 08:02 PM
Camaro_Maniac63's Avatar
If you are going to stay NA, then the 6" rods would be better. What your machinist told you is the reason why. But if you are going to be going the forced induction route, then the shorter rods are better from what I understand. But then again, i don't think it matters too much what length you go with on a street setup (I am assuming this is a street car). I went with 5.7" rods on my stroker, just because it was cheaper as a package and it made life easier for everyone since they clearance everything without any extra machine work. I am also going to spray though, so the shorter rods might come in handy then. Good luck.
Old Jan 3, 2004 | 08:14 PM
Josh-'04 GTO's Avatar
On a forced induction application, a 6.0" rod shortens the ring pack and sacrifices ultimate ring land strength vs. a 5.7" rod, which is why the shorter rods are more commonly used in blower or nitrous motors.
Old Jan 3, 2004 | 08:56 PM
CANTONRACER's Avatar
Why not 5.85"?
Old Jan 3, 2004 | 09:24 PM
jonaddis84's Avatar
Ive also heard that 6.0" rods make life "easier" on the engine, since the piston stays at TDC slightly longer or something, just something Ive heard, not sure if its true or not.
5.85" are quite a bit more $$ then 6" though correct?
Old Jan 3, 2004 | 09:35 PM
97Z-M6's Avatar
Originally posted by CANTONRACER
Why not 5.85"?
good question why not. thats what i want to know. is there any benifit from one to the other.
Old Jan 3, 2004 | 09:52 PM
As I said earlier, the differences will be minimal in a street setup. I would go with whichever you can get the best deal on.
Old Jan 3, 2004 | 10:04 PM
Why not 5.85"?
There is no reason you can't. It is a good compromise between 5.7 and 6.0 rods. The only drawback would be a more limited selection of off the shelf pistons.
Old Jan 3, 2004 | 11:53 PM
I have ran a KB off the shelf piston for years.
Old Jan 4, 2004 | 08:31 AM
S.J.S.'s Avatar
I agree.... I went with the 5.7's
Old Jan 4, 2004 | 09:43 AM
97Z-M6's Avatar
thanks alot guys the kit with 6.0 rods only csot about 50 bucks more. the kit im getting is a scat 9000 crank, 6.0 eagle forged rods and and srp pistons. for 900 bucks and he said i could up grade to a eagle forged crank for 200 bucks.
do you think i should go ahead and do a forged crank.
Old Jan 4, 2004 | 10:26 AM
jonaddis84's Avatar
I would. By the way, is that balanced? And who is the kit through?
Old Jan 4, 2004 | 01:00 PM
97Z-M6's Avatar
the kit is not balanced and they are going to balance it anyway for only a 130 $
and they are going to order it for me.
Old Jan 5, 2004 | 04:38 AM
Zepp's Avatar
Yes, get a forged crank.
Old Jan 5, 2004 | 07:54 AM
S.J.S.'s Avatar
definately!!
Devinfoote87
Feb 12, 2016 03:21 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
colts0455
Jul 24, 2015 04:51 PM
mrwz28
Jul 8, 2015 09:11 PM
