5-6k miss
Old Dec 29, 2006 | 08:30 PM
Wildwill2855's Avatar
5-6k miss
get around 5-6k shifts at 6200, it misses a few times and the mph and rpm gauge goes up and down erraticly till it finally grabs and shifts then its smooth untill its up top again. did a cam swap,added a brand new gm opti, new wires, plugs. I dont think fouled plugs would cause that to happen? Only thing i can think of would be a new coil? Everywhere else is fine untill 5000 or so? Ive searched a while but nothing that seems to fit my problems with the tacs going up and down. Ive got a 97z
found this kinda sounds similar. http://web.camaross.com/forums/showt...ight=miss+tach
Old Dec 29, 2006 | 09:20 PM
zx1216's Avatar
yeah, sounds like the coil or opti, even though its new they have been known to last 200k or 200, kinda a crapshoot...
Old Dec 30, 2006 | 09:53 AM
2000GTP's Avatar
Bad plugs, wires, or a weak coil can lead to this type of problem. I would double check your wires and plugs to verify they are in proper condition. Then I would test the coil. Shoebox has ignition coil troubleshooting steps on his site.
Old Dec 30, 2006 | 11:11 AM
i just went and got a acdelco ignition coil, doubt that was the problem, but ill go and find out later on. if it is the opti would i be able to use ltcc? Or is that part of the opti needed bad that cause this miss?
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
