4L60e and some tunercat
Max stock programming is 90 from what I have seen (usually only at or close to WOT). Too much pressure can be harmful to the tranny. If you are going to experiment, I would not go over 90 for starters. Remember the power you are wielding with Tunercat. You can cause damage if not careful.
