4l60e nightmare
Old Mar 19, 2012 | 12:46 PM
karkareco's Avatar
4l60e nightmare
i am hoping that i can get a little help here,,i bought a 94 z28 with a bad trans.when i pulled the trans i found out it had a 95 pwm trans in it,,i put a brand new 95 4l60e trans in it..then found that it only had 3rd gear safe mode but reverse worked properly..then added the wire from u pin on trans plug to d6 on the pcm and replaced pcm with a 95 pcm turning the whole setup into a 95 ....but...after all that it shifts through all the gears flawlessly except reverse..in reverse youhave to give it gas for it to move like there is no line pressure or something..but with the 94 pcm it has reverse good...i hope i can find some help i am at wits end with this thing,,thank you
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
