42lb/hr inj. or 30lbs?
Old Jul 14, 2004 | 11:12 PM
IrocSS85's Avatar
for my 383 build. I just bougth these 30lbers for the heads/cam swap. but now that im doin the 383 build should be around 425-450 RWHP when its finished. I may step up to some afr's or somthing with a bigger port if the power isnt there. so what I wanted to know is, at my power level, will the 42 lb/hr inj.s be too big to run right? or will it run the same as the 30's w/tuning obviously. I have an oportunity to buy the 42's (from a friend that owes me a favor) for $100, I know I can sell the 30's eventually for that. Im thinking if I DO get the aftermarket heads, I'll have to step up to bigger inj.s too. so why not do it now? what do you guys think? or do you think the 30's would be sufficient for a 383 with 11.1 CR, 233/239 cam, aftermarket heads, and 4.10 gears. ofcourse I have all the bolt ons too.
chris
Old Jul 14, 2004 | 11:16 PM
ninetythreez's Avatar
there is a chart for injector sizes somehwere here on the net. I have seen it from a link on this message board. Somebody hopefully will post it.
Old Jul 14, 2004 | 11:30 PM
1racerdude's Avatar
injectors
42lb'rs@56PSI will get you in the 650-700HP range,if you have the heads,intake,and cam to go that high.
Old Jul 14, 2004 | 11:32 PM
Here ya go. I found this for ya.
http://www.rceng.com/technical.htm
Old Jul 14, 2004 | 11:35 PM
1racerdude's Avatar
30lb'rs@45PSI will go 500FWHP with a 85.1 duty cycle.
13qtr
Oct 28, 2016 08:11 PM
Nutty's96
Dec 21, 2015 06:25 AM
canuck94z28
Aug 19, 2015 05:50 PM
mrwz28
Jul 8, 2015 09:11 PM
funina91ss
Aug 17, 2003 01:31 PM
