4 or 2???
Old May 27, 2005 | 09:48 AM
Z28 97's Avatar
4 or 2???
I have a 1997 Camaro Z28 and my car is currently at the shop getting its header, y-pipe catback installation and i bought 2 new rear o2 sensors...and hes telling me theres only supposed to be 2....Im lik there are 4 not 2....Im so pissed right now....there are even 4 holes for them but he still dont belive me....
Old May 27, 2005 | 10:03 AM
NewbieWar's Avatar
Re: 4 or 2???
96 and 97 camaros have 4 o2 sensors... 93-95 have only 2
Old May 27, 2005 | 10:05 AM
blaze309's Avatar
Re: 4 or 2???
There's two pre-cat o2 sensors, i think they should be around the collector's on the headers and then i guess ( I've never seen under a 96+) there's two more after the cat. So there's defintly four.
Old May 27, 2005 | 10:07 AM
NewbieWar's Avatar
Re: 4 or 2???
in 96+ there are two cats so it needs one after each cat*
Old May 27, 2005 | 10:37 AM
sssalah's Avatar
Re: 4 or 2???
It could be 96-97 and have only the front sensors if it's an "export" car like mine, but regardless of that if you're installing an aftermarket y-pipe with no cats then there's no point of getting the rear sensors. You either have to program them out or fix o2 sims, that's if it's not an "export".
Old May 27, 2005 | 10:49 AM
DiabloGT's Avatar
Re: 4 or 2???
i have a 95 with one hi flow cat, and puttin on pacesetter lts and y pipe, how many o2 sensors do i need, all it does is take away the what light? and how much will it cost?
thanks
Old May 27, 2005 | 11:01 AM
96_pimped_out's Avatar
Re: 4 or 2???
To try to make this perfectly clear you need 2 for each cat (one pre, one post). You can substitute a O2 SIM for the post only if you choose.
So,
93-95 1 cat = 2
96-97 2 cats = 4
Old May 27, 2005 | 11:35 AM
Z28SORR's Avatar
Re: 4 or 2???
STOCK 97's have four (two pre and two post Cat. O2 sensors). However some headers for the 97's convert the system to a single Cat. In which case you use the two preCat. sensor and program out the aft ones or get O2 sims. for the aft ones.
Old May 27, 2005 | 11:41 AM
Re: 4 or 2???
Good point, my post was consideringly only STOCK setup.
PS - I see you're in Friendswood, TX. My friends and I had a huge laugh because there's a "Gay Pontiac" on the frontage road right around "Friendswood Blvd" or something like that.
We found it hilarious!
Old May 27, 2005 | 12:37 PM
Z28SORR's Avatar
Re: 4 or 2???
Gay has had a dealership down here for some time. Just a few miles south on I-45 AKA the Gulf Freeway. You know what they say, "you don't get to chose your last name".
P.S. When your introduced he put out his hand and says, "howdy I'm Gay".
Old May 28, 2005 | 03:07 PM
Hyperspeed97z28's Avatar
Re: 4 or 2???
it has 4 o2 sensors ...
2 front 2 rear unless your using o2 sims ...
Old May 28, 2005 | 05:24 PM
Re: 4 or 2???
Yah, but you do have a choice in location if you're named that. And to put it near "Friends Wood" is a bad idea
Old May 28, 2005 | 07:07 PM
Robs97Z28's Avatar
Re: 4 or 2???
that is just wrong...
Old May 28, 2005 | 10:29 PM
NewbieWar's Avatar
Re: 4 or 2???
thats interesting, because my car doesnt have an o2 behind the cat... just 2 in front...
94 lt1
Old May 29, 2005 | 11:31 AM
Re: 4 or 2???
94 lt1
That's Because ...
So,
93-95 1 cat = 2
96-97 2 cats = 4
