4.10's on a full bolt on and 100shot LT1??
Old Jul 8, 2003 | 10:14 PM
Robbie's Avatar
My question is should I do it? Or should I stick with my stock gears? I already spin when i stomp it in 1st. I can imagine 4.10's and 100shot of n20. Im thinking just stay with 3.42's but i'd like your opinions. Thanks.
Old Jul 8, 2003 | 10:18 PM
norcalstreet's Avatar
If you baby them it'll be fine. I would personally be saving up for a 12-bolt at the rate you're going. If you see the track a lot and do a lot of clutch dumping off the line you'll blow a set of 4.10 gears soon enough.
Old Jul 8, 2003 | 10:37 PM
muraoka's Avatar
i run close to that same set up. i can say that i'm out of 1st at about the 40ft mark. however with 26/10.5/15 streets i trap about 6200 rpms. they are fun but on a stock bottom end and stock tire height i think 373's are a better choice. i know most would disagree but if not for the tire height i'd order 373's with my 12 bolt.
Old Jul 8, 2003 | 10:41 PM
Robbie's Avatar
And the fact that im gonna be ordering 18in wheels will hurt even more i suppose. Although it helps being a taller wheel the small sidewalls is gonna leave me begging for traction with 4.10's i would guess.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ddr698
Jan 9, 2015 10:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
