4.10's??
Old Dec 20, 2003 | 12:43 AM
  #16
MTL_Z28's Avatar
One more question...
Are 4.10's a good 1/4 mile mod?
I mean I've heard from many people that they give a real good "seat of the pants" feeling, and that this alone would make them worth having on an M6 car.
But what I would like to know is, are they good for 1/4 mile acceleration assuming the car has just bolt-ons and improved traction from DR's (once the cam is changed and other mods that would give you more top-end hp, I imagine 4.10's are ideal, however it will be a while before i touch the heads/cam). It seems like you would just run out of gear fast and lose time shifting. Am I wrong?
Thanks in advance.
Old Dec 20, 2003 | 01:23 AM
  #17
Z95m6's Avatar
When i first got my 3.90's i thought they were awesome compared to my stock 3.42's. Now i wish i would of gone 4.10's. I would say go 4.10's.
Old Dec 20, 2003 | 11:35 AM
  #18
JDMZ28's Avatar
I hear you MTL_Z28. I would like to know the answer to the same questions. Of course you are going to notice a SOTP improvement you want to know how it is going to affect you quarter mile times.
Old Dec 20, 2003 | 06:15 PM
  #19
MTL_Z28's Avatar
Hopefully someone has some input for us
*EDIT* Nevermind, I just read the other thread you started!
http://web.camaross.com/forums/showt...hreadid=205210
Old Dec 20, 2003 | 07:24 PM
  #20
Zepher's Avatar
Only problem with 4.10's and a fast car is having to shift to 5th gear at the 1000ft mark.
Once you shift to 5th, you lose a little bit of pull.
If you trap under 115mph, I think you'll be fine with 4.10's.
Oh, and the car dropped 7 tenths in the 1/4 going from 3.42 to 4.10 and adding LCA Relocation Brackets.
Old Dec 21, 2003 | 02:57 PM
  #21
nateh's Avatar
It depends on where you set your rev limiter. At 6200, the speed is at 115, but at 6500, it's at 121. If you have enough power that you're having to shift into fifth before the traps, you need a longer gear. IMO, 4.10s are a perfect match for most bolt-on or H/C f-bodies. They should have come with them from the factory.
Old Dec 21, 2003 | 03:39 PM
  #22
Zepher's Avatar
If your car isn't making power past 6200, there would be no point to raise the limiter, you'll rev higher but you won't go any faster.
The car was fine with the 4.10's without the LPE cam, once the cam, LT's and x pipe were installed the car was trapping much higher.
Old Dec 21, 2003 | 06:28 PM
  #23
KENS96M6's Avatar
I have had both, 3.73 and currently 4.10. I like the feel of the 4.10's on the street better than the 3.73. Not bad at all for me on the interstate, but I dont do 85 or above on a regular basis. Like others have said, you will have to figure out if you can use them in the quarter. Ken
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
colts0455
Jul 24, 2015 04:51 PM
